We are partially excavating into a space under our house to create some storage. There will be a wall about 4’high, holding back some fairly moist soil. With limited access, what do you suggest I put on the exterior of the wall after I strip off the concrete forms. I’ll have about six inches from the soil before backfill. what should I put in that space to reduce moisture penetrating this space?
I’ve thought about a heavy plastic covered with a thin layer of hard insulation (to protect the plastic.
I also thought I should install a perforated pipe drain at the base of the wall. Should I put the drain pipe on the exterior side of the wall, covering it with gravel?
Any other suggestions on where to get info on this?
Thanks!
We are partially excavating into a space under our house to create some storage. There will be a wall about 4'high, holding back some fairly moist soil. With limited access, what do you suggest I put on the exterior of the wall after I strip off the concrete forms. I'll have about six inches from the soil before backfill. what should I put in that space to reduce moisture penetrating this space?
I've thought about a heavy plastic covered with a thin layer of hard insulation (to protect the plastic.
Thanks!
