I’m an intermediate do-it-yourselfer and have put down several standard hardwood floors of the 2 1/4″ variety with desent results. We’re building a new home and ran across what seemed to be a good deal at Lumber Liquidators……… 5″ X 3/4″ oak flooring for $3.65/ square foot. Well we bought a 1000 square feet of it and when we opened the boxes there are only 2 lengths of flooring in it, 27 1/2” & 31 1/2″.
The stuff I used in the past had a wide variety of lengths so was pretty easy to avoid having a pattern appear and staggering the seams. I’m worried that with only 2 lengths it’s going to be hard to not have some type of pattern emerging. In the wider material is this a ‘normal’ situation (boards of similar lengths) & if so (or not) am I right in my concern over the pattern issue and if so what is the fix? Thanks
Shorts are common...actually, they're not just common...they're the norm, for Lumber Liquidators.
It can make layout a bit tougher, just go your best to stagger without having the offset be the same with each row.
You'll be super-critical of how it looks as you lay it out, but like most things, after a few weeks you'll have forgotten about all the angst during installation.
Thanks, that was the type of answer I was hoping for.
i have seen their ads for years,
and always wondered.....
thanks for the post- for those prices i don't need the hassle...
carpenter in transition
