4-way swicth help requested
| Posted in General Discussion on March 6, 2000 12:34pm
My foyer light is controlled by a 4-way switch. When I replaced these switches (one 4-way, and two 3-way) with decorative ones, something went awry. When the 4-way switch is on one position, neither of the two 3-way switches would work. The only way I can control this foyer light at present is to make sure that the 4-way switch is always in one position, and then both 3-way switches would work.
I think I tested all the switches using a continuity tester and they seem to
all work. Also using the continuity tested, the wires appear not to be disrupted. I think I followed the switch manufacturers wiring instructions. Can you help me troubleshoot the problem?
Bing G. Ticse
Millstone, NJ
  1. Guest_ | Mar 01, 2000 06:14pm | #1
    It'll work. Bypass the 4way and get the 3ways working first--then swap wires on the 4way till everything works.
    1. Guest_ | Mar 01, 2000 10:43pm | #2
      *The most common problem is usually that the "travelers" are switched - that being the wires that carry the current between switches. I would try switching positions on the four-way with only one set of wires first.
      1. Guest_ | Mar 01, 2000 10:52pm | #3
        *Go to for a description and diagram. Sound like you may have the reds and whites mixed up at the 4-way switch.
  2. Mark_M | Mar 06, 2000 12:34am | #4
    I agree, to put it simply; you wired into the sides, instead of into the top and bottom ( or visa versa depending on the manufacturer )
  3. Bing_G._Ticse | Mar 06, 2000 12:34am | #5
    Bing G. Ticse
    Millstone, NJ
