I have about 600 SF of prefinished 3/4 x 3-1/2 red oak flooring stocked upstairs waiting for installation. It has a stain + poly finish from the factory, both sides, both ends, both edges of every piece. The day it arrived I opened a few boxes and it meters at 5% MC. Subfloor is at 10% MC. After 3 weeks there has been absolutely no change in that 5% reading, none at all, even for pieces that are simply leaning against the wall with nothing around them. I’m prepared to wait a while longer, as I’d rather have a 2 percentage point difference at most. Anyone else had to wait this stuff out?
Michael Hindle explores the efficacy of deep energy retrofits and discusses essential considerations for effective climate mitigation.
Must be the dry winter weather in WA.
I've got an idea. Cover the subfloor with poly, and run one of those kid's sickroom humidifiers for a while and see if that helps the boards.
Forrest - shooting in the dark
Glad your sig. line didn't appearr in the fortune cookie thread in the Tav.Spheramid Enterprises Architectural Woodworks
The material is sold by a Canadian company that's not far from here, but it's manufactured in China. I was a little surprised when saw that on the boxes. Inside the boxes, the material is wrapped in thin layers of foam sheeting, which would no doubt inhibit moisture changes quite well. I assume that raw logs were shipped to China where they were sawn, milled, dried, etc. and that the low MC is from that stage.
I suppose I could add humidity to the room, but I think there's already plenty there and what I'm seeing is that the finish really slows any changes in MC. The room is about 22 feet wide so even a 1% increase in the total width of the installed floor would be disastrous. This install may wait a long time.
<< it meters at 5% MC. Subfloor is at 10% MC. After 3 weeks there has been absolutely no change in that 5% reading>>>
Accuracy falls off quickly at the lo range, maybe you are closer to that recommended 4% difference than you think.
I had the same problem 3 years ago, no change in MC after the 3/4 prefinished flooring sat out for almost a month. Gave up and installed it and so far no problems.
