In every issue you'll find...
  • Expert insights on techniques and principles
  • Unbiased tool reviews
  • Step-by-step details to master the job
  • Field-tested advice and know-how
Subscribe Now!
Acid staining and radiant heat
toolinaround | Posted in Construction Techniques on October 16, 2005 05:45am
Hey gang,
getting ready to acid stain new pour, and thought I read something awhile back regarding radiant heat, and that prior to putting flooring down, you should run the radiant heat, (if it’s never been run) for a couple of hours.  Sound familiar at all.  Don’t remember, but might have had something to do with moisture….thanks for any help in advance….Beck
Re-Home Solutions Inc.
  1. ruffmike | Oct 16, 2005 06:45pm | #1
    I acid stained my slab and did nothing special because of the radiant system. Just follow acid staining and sealing recommendations. Good luck, we love our floor. After staining and one coat of sealer, we covered the floor with paper for protection. We used that red paper from home depot, available by tarps/ dropcloths,( some type of cheap roofing paper) worked good.
                                Mike
  2. Clyde | Oct 16, 2005 07:44pm | #2
      I have applied concrete stain previously and done a good deal of decorative work in that regard, but never have applied acid stain.  I like the effect, however, and am considering using an acid stain on an old concrete floor (no radiant heat).  Problem:  There is a 1/4 - 3/8 inch crack across one section of the floor.  What is the best way to fill and seal this so that it won't be visible/ stand apart from the rest of the floor once sealed?  Also, what acid stain products have you found to be best or best avoided?  Do most come with good instructions?
    1. brownbagg | Oct 16, 2005 08:31pm | #3
      it will look better if you leave the crack alone, seems like the worst looking slabs come out the best.
      1. Clyde | Oct 16, 2005 09:20pm | #4
        Okay.  thanks.  What about products?  Application advice?
        1. brownbagg | Oct 17, 2005 01:02am | #5
          I used Kemiko stain and a pump up sprayer. Kemiko.com acid-stain.com
          1. Clyde | Oct 17, 2005 01:26pm | #7
            I've seen their ads and sent off for information.  They have a brochure, but it doesn't provide a lot of information.  When you buy the product (or before you buy the product) do they send more detailed info reference application, special effects, do's and don'ts?
        2. ruffmike | Oct 17, 2005 06:14am | #6
          Brownbag is right, the crack can add ambiance. Check out http://www.acidstain.com boards for info. on methods/ products                            Mike
          1. Clyde | Oct 17, 2005 01:41pm | #8
            Thanks, this is a great resource!
Reusable Flood Bags for Fast Bulk-Water Control
These bags from Quick Dam arrive compact and swell to form a protective barrier on contact with water.
Get an overview of the process of creating a traditional-style fireplace that burns well and meets current building codes from experienced mason Mike Mehaffey.
  • Keep Craft Alive Podcast: Episode 20, Ian Schwandt, TDS Custom Construction
  • Installing Prehung Exterior Doors
  • Podcast 485: Air-Sealing a Mobile Home, Owner/Builder Tests, and Ready-to-Tile Shower Bases
  • Podcast 485: Members-only Aftershow
BOOKS, DVDs, & MERCH
Shop the Store
  • Pretty Good House
    Buy Now
  • Outdoor Projects
    Buy Now
    Buy Now
  • 2021 Fine Homebuilding Archive
    Buy Now
  • Shop the Store
  • Issue 309 - Aug/Sept
    • 10 Steps to Install Crown Molding on Cabinets
    • How to Get Sturdy Walls Without OSB
    • Choosing the Right Construction Tape for the Job
  • Issue 308 - July 2022
    • Pretty Good House Book Excerpt: Copper Farmhouse
    • 10 Dos and Don'ts for Electric In-Floor Heat
    • A Sturdy Rail for Outdoor Stairs
  • Issue 307 - June 2022
    • How to Raise a Post-Frame Home
    • Trimming Deck Stairs
    • Evolving an Energy-Efficient Envelope
  • Issue 306 - April/May 2022
    • Framing Stairs to an Out-of-Level Landing
    • Building a Zero-Energy Home for Less
    • Good-Looking and Long-Lasting Traditional Gutters
  • Issue 305 - Feb/March 2022
    • The Steady Surge in Residential Solar
    • The Fine Homebuilding Interview: William B. Rose
    • How Good Is Your Air Barrier?
  • twitter
Taunton Network
  • Copyright
  • Do not sell my information
© 2022 The Taunton Press, Inc. All rights reserved.
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
