any body work with the “acme – cash fittings
these are available at my supply yard and can be used with copper pex etc and require no tools to install or remove as they use a pressure seal and are good gto 150 psi
bought a few but wondering if anybody has had reults with them
Dude, There is a fitting that my plumber uses called a sharkbite. Could this be the fitting you speak of? Jay
Yep.http://www.cashacme.com/sharkbite.phpSo a search of sharkbite. IIRC it was generally like, but to expensive for regular use..
Bill, We do a lot of Kitchen and bath remodeling and I use the sharbites to cap off existing plumbing during demo until the plumber gets on the job. Although they are expensive they save us money because a carpenter can slip them on with out having to call in the plumber during the demo phase. Jay
souns like it is the "shark bite" and they are not cheap
when your paying labour and only doing 1 or 2 fittings or in a tight spot for a torch they look a lot cheaper
