Add color to flagstone treads?
BigRodent | Posted in General Discussion on April 20, 2006 09:20am
I am putting down a flagstone walkway/stairs set in mortar over a cement base.  When I first put on the stair treads the color seemed a bit off but nothing to be alarmed about.  Until it was all done… The treads that they gave me were definitely more of a bluestone whereas the field of the flagstone is a fullcolor mix.  (mostly greens, some browns and some lilac but no blue)
Is there anyway to add a dye or stain to the bluestone that will make it slightly greener in color?  I have seen a few brick stains that would work but they are saying that they are not for floor/horizontal applications.
Thanks!
  1. peteshlagor | Apr 21, 2006 01:13am | #1
    http://www.miracote.com
    Look at their concrete stains.  Two completely different types available - nonacidic and acidic.  They each have their place.  Read and learn about them.
    1. BigRodent | Apr 21, 2006 03:57am | #3
      Thanks for the pointer.  I'll definitely check out the specs and contact them before attempting it.  All of the other concrete stains I had found were powders so this will be a good option.
  2. pino | Apr 21, 2006 02:20am | #2
    Might be obvious, but if you choose to try concretee stains be sure to do a test on a scrap piece first. Its definitely more art (or alchemy) than science with this stuff.
    1. BigRodent | Apr 21, 2006 03:58am | #4
      I will definitely test it out quite a bit.  I am not sure if I should add yellow to make it more green or if I should just add green.  Either way, it will be added slowly and quite diluted to start. :-)
