I have a 4.5 gallon DeWalt air compressor that is about 5 years old that is a bear to start up in cold temps. I have to warm it up inside or put a 100 watt bulb on it for 30 minutes or it trips the reset button multiple times. Is there anything that can be done to fix this or do I just have to warm it up?
There's a constant source of clean water for you to use, and all you have to do is collect it.
you've opened the drain valve left it open ? let it warm itself up b/4 closing.
Use a thinner oil if not oiless.
http://www.quittintime.com/
You have to warm it up
If you're doing a lot of cold weather work, get an oil-less compressor. They start in any weather.
Solar & Super-Insulated Healthy Homes
We used to set ours next to our truck exaust for awhile before starting it. Other times, we'd store it in our JOBOX with a light bulb on all night.
As other have mentioned, make sure you have everything wide open and no pressure building.
