I have a house that they have a 1950 vintage American Standard toilet in pink. As it matches all the tile, I’m wondering if there are ways to retrofit it to a low flush type and have it flush decently. It can’t be replaced in that same color.
You can retrifit most of them. Most folks just displace some water by putting someting the in the tank - bricks, etc.
This thing replaces the handle. Up is a regular flush and down and is low-flow flush.
The Controllable Flush works with 3.5-, 5- and 7-gallon tanks. It's available for $30 at http://www.controllableflush.com or by calling 1-888-426-7383.
You can't really retrofit to a true low flush and have it flush reliably, especially one of that vintage that may use 5-6 gallons per flush. The bowl for a low flush toilet needs to be designed to handle the lower volume. (And, in particular, the bowl needs to HAVE a lower volume -- many of the older units have a bowl with about a 2 gallon capacity, which obviously isn't going to flush with 1.6 gallons.)
There are ways to reduce by maybe 1/3 the volume of the flush, such as sticking bricks in the tank, or adding dams. And possibly a pressure flush retrofit could be done, reducing volume by 1/2 or so.
