I have a friend that has a plumbing leak on a swimming pool. It is inside of the return pvc pipe that goes to the return jet. The pool is a fiberglass type and getting to the supposed leak would require to cut a large hole in the concrete to gain access to the area.
Looking through the internet is a product from a company in Canada called fix a leak, anyone heard of them and can vouch for the product?
Semper Fi
“To be young and a conservative, you have no heart”
“To be old and a liberal, you have no mind”
Winston Churchill
“Some people spend an entire lifetime wondering if they made a difference. The Marines don’t have that problem.”
PRESIDENT RONALD REAGAN, 1985
Try http://www.poolcenter.com You can find out anything there.
Great minds think a like! That is the site I originally found the product I posted the thread. Thanks!Semper Fi
"To be young and a conservative, you have no heart"
"To be old and a liberal, you have no mind"
Winston Churchill
"Some people spend an entire lifetime wondering if they made a difference. The Marines don't have that problem."PRESIDENT RONALD REAGAN, 1985
I HAD A SIMILAR LEAK IN MY POOL AT THE SKIMMER . I USED THIS EPOXY AQUA STICK SEE LINK http://WWW.EPOXYGATOR.COM IT WORKED GREAT. I USED A LITTLE FOOD COLORING IN AN EYEDROPPER TO DETECT EXACTLY WHERE THE LEAK WAS AS SOON AS I PUT A COUPLE OF DROPS IN THE WATER NEAR WHERE THE TILE & THE PLASTIC SKIMMER MEET THE DYE WAS SUCKED IN AND THAT'S WHERE THE LEAK WAS
LOL, your link went to Tauntons web site. I did look at the web site and the product does look good. Problem would be ok using this product if we had easy access to the hole or crack. We were looking for something that could be used in areas we can't actually or visually "see". Semper Fi
Winston Churchill
try a site caller smarter.com in the search bar type in what your looking for
Thanks! I'll check it out.Semper Fi
Winston Churchill
