I want to make a couple of concrete columns for a driveway gate. I want to put local slate on the outside of the concrete. When the slate is dry it looks dusty and dirty. What do I use to give the rock the permanent “wet” look? I’m also concrened about UV sensitivity, “refinishing”, and weather-proofness.
Any help would be great thanx!
-Kris.
Learn how to fight wood-boring beetles and prevent home infestations with expert advice from Richard D. Kramer, an authority in pest control.
Sealers can behave differently on different types of stone. No big suprise there.
Take a few samples pieces of your stone. Use a cleaner, then a sealer on a portion of the stone. Keep trying until you get the finish you desire.
Some sealers have a dull, matte finish, other have the glossy, wet look that you seem to be looking for.
A penetating sealer is easier to renew than one that forms a film finish. Most penetrating sealers can simply be wiped on again as required, whereas some film-finishes need to have the original coating stripped off before applying again.
I want to make a couple of concrete columns for a driveway gate. I want to put local slate on the outside of the concrete. When the slate is dry it looks dusty and dirty. What do I use to give the rock the permanent "wet" look? I'm also concrened about UV sensitivity, "refinishing", and weather-proofness.
-Kris.
