In every issue you'll find...
  • Expert insights on techniques and principles
  • Unbiased tool reviews
  • Step-by-step details to master the job
  • Field-tested advice and know-how
Subscribe Now!
applying texture to walls….
chrisfox | Posted in General Discussion on March 8, 2007 07:19am
I posted a few weeks ago about this, now just getting around to testing the texture tonight. A co worker has a Texture Pro hopper gun by Walboard. Attached are a few pics. I am using a tip that has .25″ opening, the largest he has. The area I am doign first is in a walk in closet, not so picky here but the bathroom other side of wall is critical to blend in as best as I can.
I mixed mud to oatmeal consistancy and get small grouped together mud plater that pretty much covers the entire area. (see attached pic) The air is set at 25psi.
I mixed in very little water – not much of a difference.
I experimented with flicking it on(attached is a pic)
Also attached is the texture of the eniter home which I am attempting to match, my hand is in the pic to show scale. The texture looks very thick blobs that have been knocked down with alot of area between – not so close and thick.
Any ideas to pass on?
thansk again for the all the help.
Chris
  1. rez | Mar 08, 2007 07:32am | #1
    I was just going to say that first pic looked ok then I read it was the existing. Roar!
    Tim or others should be along to help you out.
    Cheers
    every court needs a jester
  2. 1muff2muff | Mar 08, 2007 07:39am | #2
    Are you trying to match the existing? (new here missed first part)
    1. chrisfox | Mar 08, 2007 09:17am | #8
      1muff...
      I am remodeling a master bath and added a pocket door to a closet, the walls are vaulted and need to blend in the texture. I hate texturing, now spending the time trying to get the hang of it. I only need to blend in a 8 sq ft of wall.
  3. calvin | Mar 08, 2007 07:40am | #3
    sorry, can't comment on the mix.  How long did you wait till you knocked it down.  Looks like it was too soft when you hit it.
    http://www.quittintime.com/
  4. 1muff2muff | Mar 08, 2007 08:00am | #4
    Your existing reminds me of afloor leveling mix I used years ago. It would go from a liquid to a solid about 30 seconds after a wet mix. Flick it, and hit it with trowel.
  5. IdahoDon | Mar 08, 2007 08:00am | #5
    What are you knocking it down with?  A lightweight knockdown blade is much easier to use than a 12" knife.  The key is waiting until it's starting to firm up, but not so firm that it can't be flattened.
    Practice with slight variations until you get it.
    I like a little more pressure (50 lbs) and simply adjust the air delivery ball valve to what works best.
    1. chrisfox | Mar 08, 2007 09:20am | #10
      I am using a large heavy staright edge knife that the co worker had stuck in the box, so scraping the set mud(20-30min) at 45 deg. I will increase the air flow.
      You think thickening the mud(less water) would give me the heavy blobs?
  6. dovetail97128 | Mar 08, 2007 08:06am | #6
    I am no expert and I may well be wrong but I am thinking that what you have in the existing is not a sprayed on texture that was knocked down. It looks more like a hand applied "brocade" .
    A "brocade" here is put on by using a simple tool that looks like an plaster hawk with carpet ot plastic wrapped over the top of it, after applying the mud the mud is "knocked down" using a broad knife.
    Similiar to the old hand plastered look that was done with a plasterers trowel in a "skip" fashion.
    1. chrisfox | Mar 08, 2007 09:13am | #7
      Dovetail,
      This is a semi track Phoenix, AZ home(1995), so figure guys tear through these houses pretty fast. My guess it would be with a hopper. I will have to reseach Brocade technique a little more.
      chris
      1. dovetail97128 | Mar 08, 2007 09:18am | #9
        Like I said I may be wrong. But tracks here have been done with brocade quite often.
        Heavier mix , not as wet , bit more air, stand back about 4', let it "skin" a bit before knocking down .
        1. chrisfox | Mar 08, 2007 09:22am | #11
          Come to think of it I was pretty close to these test baords, standing back may give me the blobing effect I need.
          1. catfish | Mar 09, 2007 01:38am | #15
            I've had good luck with the mud thinned to where it fell back together as soon as you drug a finger thru it.  HO  has done the whole house, with different helpers  We tried around 30 to 35 psi
  7. User avater
    xxPaulCPxx | Mar 08, 2007 10:28am | #12
    The "Thick Splatter.jpg" looks more like the "orange peel" texture I have in my bathrooms.
    Please keep posting your progress, and mistakes... we all can learn from both.
    Also a CRX fanatic!
  8. 5brown1 | Mar 08, 2007 04:34pm | #13
    I'm not an expert but it sounds like you need to thin out the mudd and go to a smaller hole and about 45 lbs pressure. You really don't want to wait too long before knocking the mudd down. Keep the blade almost perpendicular to the wall and just let it glide over the mudd.
    Get some cardboard and practice getting the mix just right. I find that usually the problem I tend to have is not getting the mudd thin enough.
    Good luck with a little experimenting it will turn out great.
    1. IdahoDon | Mar 09, 2007 05:10am | #17
      I was thinking the same thing, thinning the mud a little will let the mud spread out more easily.
  9. valleyboy | Mar 08, 2007 05:57pm | #14
    I am not an expert by any means but I did do all the ceilings in my house to achieve what you are after.
    I first put on a thin layer of drywall mud (about 4'x4' area), then use a tile float and push it into the mud and then pull down quickly.  This leaves an even look of pointed mud.  After about 20 mins or so, I use a 12" drywall tool to flatten the points.  The finished look is what we call "California" finish.
    It actually came out very well and after using the textured look in a few houses I built, this is quite a change.  I do have a hopper and tried it once and was not successful so used the above approach.
    If you only have a small area, you could easily match it using this technique.
    1. rez | Mar 09, 2007 03:17am | #16
      What is the 12" drywall tool you use for flattening the points?
      I've been using that exact technique for years now and never knew it had a name. Like the true random effect and makes it easy to match late in the event of a patch.
      1. valleyboy | Mar 09, 2007 03:57pm | #18
        The 12" tool is just a normal 12" mud applicator only I rounded out the two corners.  Without the rounded corners, I got marks from the corners.  When the mud dried to fairly hard, I just used the applicator to flatten the surface.  Almost no pressure applied.
        When I applied the mud to the drywall, I liked it nice and sticky....not too thin....that way the float pulled the mud down nice.  If you have it too thin, it took too long to dry and if I flattened it when too wet, it gave too large an area of flat spots.
        All in all, took some practice to get everything right but the job, when done, is very nice.
        1. chrisfox | Mar 09, 2007 07:45pm | #19
          Thanks all for the good input. I will let you know how this turns out.
        2. rez | Mar 09, 2007 08:43pm | #20
          Yes, I like a lightweight plastic straightedge with the rounded corners to help prevent the errant occasional straightline that always wants to crop up if the feathertouch ever gets a bit too heavy. Roar!
          I use a wooden float with rounded convex edges to level the mix and pull for the pucker power to make the mountain caps.
          Started doing walls the same way and find that people often will stop walking and stare at it, then usually a positive comment about those walls.
          I haven't experimented with it yet but it seems to me that a sculpted design or scenery pic, or even a shadowbox type drywall paste side profile portrait of Marilyn could be hidden in those random patterns only viewable if one is looking for it.
          be a wild thought
          1. valleyboy | Mar 10, 2007 04:57pm | #21
            You mentioned that you do walls that way also......here's what I did with a wall that is 10' along one wall and they goes to 20' high for the gable end....inside walls.
            I mix drywall mud with stuff used for texture ceiling spray then use a 6" drywall knife to apply it to the wall.....the texture mix keeps the sheen off the wall that drywall mud seems to make it.   I use random strokes with the 6" knife to apply it so that you see the ridges and strokes of the knife.  Painting is a real PITA as I found I could only use a brush to get into the ridges but have two walls done in deep maroon that is really nice looking.
            All in all, it is amazing what one can do with little money and some imagination.
The Fine Homebuilding Interview: Emily Mottram
A Maine architect speaks about Pretty Good House and biophilic design principles that adapt to all climates.
Get an overview of the process of creating a traditional-style fireplace that burns well and meets current building codes from experienced mason Mike Mehaffey.
  • Keep Craft Alive Podcast: Episode 20, Ian Schwandt, TDS Custom Construction
  • Installing Prehung Exterior Doors
  • Podcast 485: Air-Sealing a Mobile Home, Owner/Builder Tests, and Ready-to-Tile Shower Bases
  • Podcast 485: Members-only Aftershow
BOOKS, DVDs, & MERCH
Shop the Store
  • Outdoor Projects
    Buy Now
  • 2021 Fine Homebuilding Archive
    Buy Now
    Buy Now
  • Pretty Good House
    Buy Now
  • Shop the Store
  • Issue 309 - Aug/Sept
    • 10 Steps to Install Crown Molding on Cabinets
    • How to Get Sturdy Walls Without OSB
    • Choosing the Right Construction Tape for the Job
  • Issue 308 - July 2022
    • Pretty Good House Book Excerpt: Copper Farmhouse
    • 10 Dos and Don'ts for Electric In-Floor Heat
    • A Sturdy Rail for Outdoor Stairs
  • Issue 307 - June 2022
    • How to Raise a Post-Frame Home
    • Trimming Deck Stairs
    • Evolving an Energy-Efficient Envelope
  • Issue 306 - April/May 2022
    • Framing Stairs to an Out-of-Level Landing
    • Building a Zero-Energy Home for Less
    • Good-Looking and Long-Lasting Traditional Gutters
  • Issue 305 - Feb/March 2022
    • The Steady Surge in Residential Solar
    • The Fine Homebuilding Interview: William B. Rose
    • How Good Is Your Air Barrier?
  • twitter
Taunton Network
  • Copyright
  • Do not sell my information
© 2022 The Taunton Press, Inc. All rights reserved.
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
