I’m going to install a whole-house fan and I’m concerned about cutting through a textured ceiling and the possible asbestos risk. I haven’t had the ceiling tested to see what amount of asbestos, if any, that it contains. The house was built in 1954 and I believe the textured ceiling was probably done in the 70’s. So, assuming that it does have some asbestos content, how can I minimize my risk of spreading it around? I was thinking of marking out the section to be cut and then spraying the cut line with water to soften the textured part. Then, I could scrape the wet “goo” off before cutting, rather than cut through dry asbestos and have it flake off. Does that sound like a good idea? Any other suggestions? No matter how I do it, the level of free asbestos is probably low, but I’d like to take any reasonably easy precautions.
I'm going to install a whole-house fan and I'm concerned about cutting through a textured ceiling and the possible asbestos risk. I haven't had the ceiling tested to see what amount of asbestos, if any, that it contains. The house was built in 1954 and I believe the textured ceiling was probably done in the 70's. So, assuming that it does have some asbestos content, how can I minimize my risk of spreading it around? I was thinking of marking out the section to be cut and then spraying the cut line with water to soften the textured part. Then, I could scrape the wet "goo" off before cutting, rather than cut through dry asbestos and have it flake off. Does that sound like a good idea? Any other suggestions? No matter how I do it, the level of free asbestos is probably low, but I'd like to take any reasonably easy precautions.
Greg,
First isolate the area you are working in by taping it off with plastic ( floors and walls ) then cut it out the usual way making sure you use an appropriate mask and disposable overalls. Vacumm the whole area before taking down the plastic ( make sure the vacumm cleaner has a particle filter installed ).
