I need to install crown molding in a commercial building with steel framing. Any ideas on the best way to go about nailing this up and are there gun nails available?
Patrick chats with the BS* + Beer crew at this year's International Builders' Show.
If you are using steel studs and the guage is lighter than 16 then I have had luck with finish screws...the tedious #1 bit jobbies...but they do the trick. Some pre-drilling might be necessary depending on your stud guage and application. Good luck with the job!
Eman
slick, I've used an inverted basebd (SE-9) as a backer on the wall, screwed in the area that gets covered w/crown. A 1x2 works nice as a backer screwed from the top through susp ceiling grid. Cut the tile, rabbit to the 1/2 with shadowline. Constant nail surface, very nice looking.
Or, pin and glue triangular blocks to the sheetrock every 16", blocks just a bit smaller than the backside dimension of the crown.
Quittin' Time
Edited 10/1/2004 10:52 pm ET by calvin
Cal .. I find it quicker/easier to just run a 2x thru the table saw and make a beveled rip ... then attach the whole stick of lumber to the wall/ceiling ...
JeffBuck Construction, llc Pittsburgh,PA
Artistry in Carpentry
and when I remember ... I leave it short of the corners a coupla inches ...
helps the crown sit better it the joint compound is heavy.
