I need help finding a tool….
Just as the title says, I’m looking for an air stapler that has an adjustable automatic mode and a single shot mode. Senco used to make one but the brand’s not important. Reliability in hot and cold is.
Something like an upholsterer would use. Light wire staples, w/ 3/8″ ish crown.
I’m looking at a project with lots of little staples.
Thanks for the help.
Garett
I bought a Duofast a few weeks ago, that gun kicks azz.
You can write your name with it. Single shot and fully automatic capabilities. 1/2" wire crown staples.
Great gun check into it.
What the problem is?
PC makes the upholstery stapler. No safety. Punches out the staples as fast as you can pull the trigger. Never seen one go "full auto"
If you have never seen one go full auto you are missin out dude.
Mine does, I can't wait to pull it out of the truck every day.
It has the dual trigger setup, if both triggers are pulled it will fire the staples until its empty. No nose safety either.
You have to be careful with it.
Thanks for the quick response.What is the model number for the dual triger gun?Thanks,Garett
I can get it for you tommorrow. Buy it man you won't be disappointed.
While your at it, where did you get yours? I'm not near any "good" tool sources. Mail order or on-line are my mose common options. Garett
I got mine from Fastenal in Grand Rapids MI.
Model # 5020 DLAF Duofast Stapler.
Thanks again, I'll do some looking around here.Garett
