My house has an exterior stairwell to the basement that was probably installed after the house was built (no concrete header over the doorway–see pic). I want to install some sort of awning over it because there’s no drain at the bottom. The plan is to remove pipe railings, attach a few 4×4 beams, and put up a shingled or polycarbonate roof out past the width of the stairwell, leaving the sides open. The only problem that I can see is that the bathroom window (on the top right) is just under 7′ to the base, and any awning would have little or no slope underneath it if I want to walk under it without stooping. Any ideas? Should I think more grandly and put the awning over the windows instead, making them jut out much further?
There's a constant source of clean water for you to use, and all you have to do is collect it.
Unless you have a hewavy snowfall, the polycarbonate in the two or three ply would be substantial and not need much slope.
