I installed my Tru Channel Storm windows from Harvey this weekend.
Looking at them this morning, I’m wondering if there’s something wrong with them. There are 3 windows, so 6 sashes total. Most of the storm window sashes have at least one gap at a corner where the rubber gasket around the glass doesn’t get all the way into the aluminum frame, which would allow air to leak in. Nothing huge, maybe 2mm x 2mm each.
Also one storm has a slight gap between the vertical casing for the sashes and the bottom horizontal casing. More air leakage although, again its slight.
Are these gaps normal? Seems like for $140/window it should be a lot better.
Bump
