Ballast Testing???
IronHelix | Posted in Energy, Heating & Insulation on September 11, 2005 02:33am
I have acquired through the years a dozen or so, supposedly “good” ballasts for mostly 8′ double tube fixtures (F96-single pin).
Is there is a way to check them out with patch cords and a meter, rather than having to wire them into a fixture??
……………Iron Helix
  1. junkhound | Sep 11, 2005 04:19pm | #1
    What type meters do you have?   Inductance & capacitance meter can check most aspects of 'goodness', but a network analyzer needed for full checkout.
    No way I know of* with a simple volt & ohms meter to tell they are good (can detect really bad ones though by looking for short). To be sure they are 'good-good', even in a fixture they need to run for > 1/2 hour to be sure of no overheating and tripping off.
    * Interested myself if somebody has figured simple check.
    1. IronHelix | Sep 11, 2005 06:24pm | #3
      Junkhound, Paul & All,
      I only have a volt/ohm meter, no network analyser!
      But Paul's link is worth the read.....and then to the shop to play for a while.
      It may be as simple in the end for me to unbox a new fixture and set it up on the workbench. Grab a handfull of alligator clips and play switcher-roo with my old ballasts.
      Hadn't thought about the run time, but I'll add it in!
      Thanks.............Iron Helix
    PaulBinCT | Sep 11, 2005 04:19pm | #2
    http://www.signweb.com/neon/cont/flusb.html
