Ballasts and Fluorescent lights
doitall | Posted in General Discussion on April 27, 2009 03:01am
Hypothetically, if a fluorescent fixture is wired to the ceiling junction box with the switched hot and neutral spliced in reverse to the ballast, would this cause the ballast to fail prematurely?
I had a a handyman install a fluorescent 4-tube fixture for my Father (in another state), and two separate fixtures have failed on this particular junction box in a short period of time. I have not had the chance to check the situation out myself, yet.
Thanks for the response.
DIA
  1. junkhound | Apr 27, 2009 04:43am | #1
    Depends on the ballast.
    Assume it is a 120 Vac standard ballast, then no for most types.
    Some electronic ballasts would fail, depending on the circuit type.
    277Vac ballasts would fail within a few months every time, but your father would need to be on a 460Vac 3 phase system to have 277Vac.
The Trump Administration Wants to Eliminate the Energy Star Program
The end of this program will likely lead to higher energy bills and fewer business opportunities for the American people.
