can i do that? Id like to make frame and panel kitchen cabinet doors, for the stiles and rails Id use bamboo flooring and rip off the toungs and grooves..
The joinery would be simple, 2 biscuits @ each joint.
This will be in my house, not a costumers, so im willing to expiriment a litte bit.
How stable is bamboo reguarding movement? seems like it would be pretty stable..
thanks..
______________________________________________
–> measure once / scribble several lines / spend some time figuring out wich scribble / cut the wrong line / get mad
I can't say I've used this for building cabs, but I don't see why it wouldn't work. I do know however that the bamboo is available in 8x4 sheets, I think about $200 per sheet, this might be useful if you need larger pieces and less work than gluing up the flooring.
wow, i diddnt realize you could get sheets, thanks______________________________________________
--> measure once / scribble several lines / spend some time figuring out wich scribble / cut the wrong line / get mad
Yeah, that sheet idea is pretty cool. Where does one begin to look for a sheet of bamboo? Spose I could try the lumberyard, but if there's another avenue, let me know.ADH Carpentry & Woodwork
http://www.greenbuildingsupply.com/Public/NaturalFlooring/BambooFloors/Plywood/index.cfm
Formerly just 'Don' but not the 'Glassmaster Don' or the lower-case 'don'.
yikes 279.00______________________________________________
I have not personally bought them, I'm a GC and my flooring guys used them for creating stair treads on a circular stair we were redoing, so I would suggest inquiring at a good (i.e. professional) flooring supplier.
good idea. thanks______________________________________________
I wouldn't use biscuits for the joints. Use two 3/8 x 2 dowels at each joint.
Wear your respirator when you cut the stuff-but you may already know. It smells nasty!
Dustin
yeah thanks for the reminder, i read somwhere that the dust particles are harsh on the lungs.. Im really bad at remembering to actually put on my resperater but i'll try hard to use self discepline..______________________________________________
why not biscuits? you dont think the bamboo would take glue as well??or put differently.. if this was oak, would you still advise against biscuits?______________________________________________
Two reasons... I think that biscuits across endgrain (your door rails) could be trouble, and I just like the deeper joint that dowels make as opposed to biscuits.
good points.. you've convinced me______________________________________________
or a half lap ...
or some pocket screws.
I'd avoid the twin biscuits too.
when in doubt .. I say ya can't go wrong with a nice strong half lap.
Jeff Buck Construction
Artistry in Carpentry
Pgh, PA
