The Portascanner uses ultrasonic technology to isolate the smallest air leaks, making it easier to air-seal an enclosure.
Delta, the made in USA version.
Did you check out Aggazanni ?
Phill Giles
The Unionville Woodwright
Unionville, Ontario
TOOL FOR HOME BUILDING might be a better place to put this thread unless you're donating the bandsaw for a Tipi Fest raffle
If Blodgett says, Tipi tipi tipi it must be so!
TipiFest 06~~> Send me your email addy for a Paypal invoice to the greatest show on earth~~>[email protected]
DOOR PRIZE! ALL RIGHTY THEN!Tipi, Tipi, Tipi!
http://www.asmallwoodworkingcompany.com
well, I just bought the Grizzly a few months ago. I'm no bandsaw fanatic, but it has done everything I expected of it.
it was the 16" on sale for about 359 or so a while back - rated best of breed by some WW magazine as I remember.
I've never had a problem with a grizzly tool
Boy, are you lucky I openned the fests folder here or you'd have stayed buried with this one by getting in the wrong folder
Piffin,
Thanks for the Grizzly review. Don't know how I got iin the fests folder...oh, well.
Brad
I've had the 18" Jet for 5 yrs. now...primarily used for resaw... works great. Adjustment with thhumbscrews of bearings a pain, but not a deal-killer. I'd buy it again, if I had to.
"The nearest thing to eternal life we will ever see on this earth is a governmental program" -Ronald Reagan
UTW,
The only complaint I'v heard about Jet is that they are under powered. That comment was in reference to the 18" though, so maybe the 16" is stronger relative to blade length.
Thanks,
Brad
a 9.6 volt battery operated cordless drill may work just fine in some situations, but not in others. I would guess that if you judge the 18" to be low(er) in power, it would depend upon what you were comparing it to.
I think the blade has a lot to do with it. I use the woodslicer from Highland Hardware. Works like a dream for me."The nearest thing to eternal life we will ever see on this earth is a governmental program" -Ronald Reagan
I know a lot of the people over in Knots use bandsaws and have discussed the which is best and how Grizzly stacks up - go over the and run the advanced search for grizzly bandsaw
Ricks,
Where do I find "knots"?
Brad
let see, emm, that a hard one. maybe top of page, right beside breaktime. BOB thinks I,m an idiot
brownbagg,
Thanks for the response. As you can tell I haven't used the forum much but found the knots querie you mentioned to be oa lot of help. Thanks Again.
Brad
