Hello, I just finished the basement article in the latest issue of FHB, and I have a question. When finishing a walk-out type basement, where at least one wall is “above grade”, is the insulating system described in the article recommended? It seems as though the wall that is above grade has the ability to dry differently than the walls that are actually underground. Would it be better to insulate some walls differently than others?
Matt
No, I'd insulate them the same way. In fact, I think that the insulation method described in my article would very well on above-grade masonry walls.
Andy
Andy Engel
Senior editor, Fine Woodworking magazine
Other people can talk about how to expand the destiny of mankind. I just want to talk about how to fix a motorcycle. I think that what I have to say has more lasting value. --Robert M. Pirsig
I agree. Nice article Andy. BTW did you notice that the Building Science article on basement insulation systems has been pulled for revision?http://www.buildingscience.com/resources/foundations/basement_insulation_systems.pdf
Billy
This issue is not yet out on news stands here. What insulation methods did they use?
