Basement HVAC Install question
amtsuchida | Posted in Energy, Heating & Insulation on September 23, 2005 07:54am
I just had my basement finished. It included installing a new hvac just for the basement. It was put in my existing furnace room that already has the hvac for the first floor and my gas water heater. The contractor installed the new hvac with an open plenum return. There is a return vent in the furnace room to the living area, but no ductwork from the vent to the hvac.
The open plenum seems to be working correctly. I can hold a piece of paper to the vent and it sticks so air is getting pulled in.
However, I have had friends tell me that an open plenum in a room with a gas furnace is very dangerous because of carbon monoxide issues. Is that correct? Is my contractor trying to kill me? Any advice would be great.
—Amy
  1. AndyEngel | Sep 23, 2005 08:22pm | #1
    Is the furnace sealed combustion? That is, is its combustion air supplied by a dedicated outside source? Or does it use inside air for combustion? If sealed combustion, it's likely no big deal. If not, then yes, a return in the basement that's not balanced with supplies in the basement can backdraft open combustion appliances. Is there a CO detector?
    Andy Engel
    Senior editor, Fine Woodworking magazine
    An updated profile is a happy profile.
    Other people can talk about how to expand the destiny of mankind. I just want to talk about how to fix a motorcycle. I think that what I have to say has more lasting value. --Robert M. Pirsig
    None of this matters in geological time.
    rjw | Sep 23, 2005 08:41pm | #2
    Doesn't your HVAC guy like you? Didn't you pay your bills
    As Andy noted, if all 3 appliances have completely sealed air intakes, combustion chambers and flues, then no problem.
    (Well, except for how the new furnace might affect static pressures of the old furnace's air system.)
    Otherwise, you might suggest to the guy who did the installation that he better be sure his E&O policy is fully paid up, and remind him that the tech who screwed up servicing the heater that killed that tennis star several years ago was faced with criminal charges.
    If any of the three is a "natural draft" appliance or has a draft inducer but draws its combustion air from that furnace room, then the guy is a complete bozo and you need to get a real heating contractor to redo his work.
    BTW, what sort of air supply does the "existing furnace room" have? It needs plenty of air when all three appliances are running.
    FWIW, I have tested the effect of an open return plenum on the draft of a natural draft furnace, as well as of furnace rooms having insufficient air supply.
    There are several factors which contribute as to whether draft is screwed up and whether the combustion gas Carbon Monoxide content goes high: size of the room they are in, existing air supply to that room, even age (and weather -tightness) of the house.
    In many cases, the draft and/or CO levels do not get screwed up, but they can and do, and this is a subject one really shouldn't play the odds on, in my opinion.
    To determine what type of appliance you have: Do they each have plastic flues AND air intakes?
    Then (and only then, you might be OK - assuming they are all properly installed and sealed.)
    Is there a "skirt" (about 5-6" across) above the water heater which allows air to mix in with the flue gases?
    Is there a "box" below either of the furnace flues with an open bottom?
    Or, is there a little fan on the front of the furnaces but with open burners?
    Sojourners: Christians for Justice and Peace
  3. amtsuchida | Sep 23, 2005 09:14pm | #3
    Thanks, guys. However, I have no idea how to answer your questions. I guess that it may be a good idea to have an inspector come in. Is any home inspector going to be able to check this or should I call an HVAC company? I am in the Atlanta suburbs if that helps.
    And yes, I paid my bills but we didn't end on a very good relationship. I would love to be able to sue him if he did it all wrong.
    And I am not turning on the air conditioning until I go get a CO detector.
    Thanks again.
    1. AndyEngel | Sep 23, 2005 09:21pm | #4
      I think you could turn on the AC, just not the heat.
      No disrespect to Bob, who is a home inspector, but I'd have a different HVAC contractor check it out. If an inspector finds a problem, then you end up paying him and the contractor you call to fix it. Ask around, find an HVAC guy with good references, and have the system checked.
       Andy Engel
Wiring for Subpanels: The Right Cables
When running cable to a subpanel for a home addition, pay attention to the size of the wire and the amperage of the breaker.
  • Podcast 549: Energy Upgrades, Chimney Inspections, and Questions About a Home You Might Buy
  • Podcast 549: Members-only Aftershow—Patios vs. Decks
  • Podcast 548: PRO TALK With Design/Build Operations Manager Jessica Bishop-Smyser
  • Strategies for Venting a Roof Valley
BOOKS, DVDs, & MERCH
Shop the Store
  • 2023 Tool Guide
    Buy Now
  • Pretty Good House
    Buy Now
    Buy Now
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
