We are recarpeting our basement (concrete floor). The previous owner had installed carpeting (no pad) via a gluedown method – which someone told me was a sign that the owner was concerned about flooding. However there are no signs of water damage and we’ve been here 2 years (during record rainfalls) and haven’t had a drop of water come in. The floor also passed the vapor test (taped plastic). Nevertheless I’m looking for installation recommendations. Specifically:
1) Should we glue down without a pad or install tack strips and use a pad?
2) If we use a pad – what type should we use? Same type okay for the stairs?
Since we will be using the room for a play area and rec room/office – we would certainly prefer the softness and “warmth” of padding:
Has anyone heard or used a special carpet pad called “Enviro Cushion” (http://www.fairwaycarpet.com/enviro.htm)? It’s supposed to be specially designed for concrete floors (100% Waterproof, No Chlorofluocarbons, 4.5 R factor, 100% Non Alergenic, 3/8″ thick, 15 lb. Density Feel). However it’s $6.50 sq yd OUCH!
Our carpet store – which never heard of Enviro Cushion – is recommending a waffled synthetic rubber pad that has a polyester (Textron) backing (“Sterlingate Signature”).
As an aside, at our last house the installer recommended/used a felt pad under berber – maybe because it was more breathable (not sure).
Any feedback would be greatly appreciated.
