I am in the process of gutting a bathroom for a customer and they want wood wainscot on the walls. My problem is that I am concerned about the moisture level. I checked into GP Ply-Bead. And for the most part, they don’t recomend it in damp or “high moisture” areas. What can I do to insure a long lasting product other than good priming and high quality paints? Or is there a better product out there?
There's a constant source of clean water for you to use, and all you have to do is collect it.
Make sure your wood wainscot is dried to the appropriate moisture level and seal the back side (ends too if you can pre -cut the pieces). This should help eliminate much of the movement.
Steve
There's also beadboard plywood, I've used it plenty. and like it alot...
