Bending copper coil for ledger??
Espo | Posted in General Discussion on May 10, 2005 04:32am
Hi All,
I’ve purchased a roll of copper flashing to be used to flash the ledger for a deck I’m building at my home. Do I need a bending brake to form this material so it slips up under the siding and does an upside down “L” over the ledger, or can I simply slide the copper up under the siding, then “form” the bends I need with a 2×4 and a mallet?
Seems like the copper will be hidden by the decking, so as long as it covers the ledger it would seem to be an OK way to go…any comments?
Thanks,
Dave
  1. DanH | May 10, 2005 06:13am | #1
    For that purpose you can probably bang it into the right shape, using a few pieces of lumber. Though it's probably easiest if you cut it into about 6' lengths and lap them (about 6") after forming.
    BTW, the proper term is "forming", not "bending".
FHB Podcast Segment: Patching Drywall Near a Shower
Learn how to patch drywall above a fiberglass shower without totally redoing everything.
  • FHB Podcast Segment: Patching Drywall Near a Shower
  • The Unabashed Maximalist
