What is the best air/hand grease gun that is on the market today?
I would like the option of using my compressor or not.
Thanks ahead of time for your input.
There's a constant source of clean water for you to use, and all you have to do is collect it.
I got one from the land down under . Mfgd by MacNaught has an eight foot hose and a hand gun that switches from 1000 psi to 10,000 psi with a push of a button. Works great . It also uses the small can of grease rather than tubes so it last longer on refills.
The M3A1 I thought was the best grease gun.
But Gunner might have a different opinion.
http://www.brass-cartridge.com/M3A1%20Grease%20Gun.jpg
I do alot of mechanic work, almost daily. The best grease gun I ever had, and I still use is an air power by Blue Point, which is snap on.
