Here is something I haven’t seen before,
http://www.myoldhousejournal.com/forum/topics/2114602:Topic:781
For those of you who have occasion to remove window glazing. It is a hot plate with protection for the glass. I can’t locate the one referenced from C.R. Laurence though.
If you have an old heat plate, there might be a way to modify it to work like this.
Not 2 hours ago, my painter and I were talking about that. He has one (out on loan), the infared bulb is VERY fragile and very $$.
So I said, sounds like a Halogen bulb in a worklight , always blowing so easy...THEN MY light came on, use a 500w halo flood, with the cage removed as a heater on putty...!!!!!!!!!
AH HA! A stroke of genius! I'll try it here at my shop before I brag TOO much.
BTW, I THINK they are no longer available, I searched and searched, NADA. All the spare parts are available tho'.
http://www.youtube.com/watch?v=Dj_oEx4-Mc4
I don't see the old Milwaukee heat plates anymore either, which is basically what one of these is, just with some more shielding. I've still got my heat plate, I might try and make something up if I ever get around to the basement windows.BTW, there are infared paint removers out there, so there might be some bulbs too. I like the halogen idea, but it might heat the surrounding area more too.
RE: surrounding area, these sash are getting stripped as well, so the blister may not be a problem. I just realized all my Q-Beams are dead bulbs, so I have not had a chance to test my ideer yet..BTW them 500W Q Halo bulbs are cheaper than dirt at Harbor Frieght.
I have duel tube , fan forced radiant quartz heater here that one of the "tubes" broke..I fired it up and sure enough it stayed dead on that tube. Then suddenly I heard ( and smelled) a sizzle..looked over at it and it was arching and the "broke" tube was working. I might cannibilize the heater and salvage the ends that connect the tube to power and , I guess they can be trimmed to length somehow.
I think with some hardie scraps, copper shield, and maybe a ridgid frame, I might could kill myself or burn a house down..LOL.
I be on it as soon as the smoke from my last cobble-up clears the room and the wife comes home to call 911.Spheramid Enterprises Architectural Woodworks
You need to train one of them mutts to dial 911 for you. Maybe put the fire department on speed dial...
There are definitely a lot of home-brew solutions like your idea out there:
http://www.oceanmanorhouse.com/?page=paintremoverZ
Reply by Jane Powell on September 18, 2008 at 10:58pm
I came upon a tip for removing glazing putty in an old copy of American Carpenter and Builder- it involved coating the putty with gasoline and then setting it on fire! It might work, but I don't think I'd recommend it...
Here's the best one from that site, but I would say douse instead of coating. :)
