The attached pic shows some trusses above a garage with 2×6 bottom chords.
The plates seem a bit wimpy to me though, and I was wondering if this type of chord is designed to carry loads (storage)
It's hard to tell a lot from one picture. Can you give me a bit more info?
What span and pitch am I looking at?
Got a picture where I can see most of the truss? Or even a rough sketch of the web pattern?
Hippopotomonstrosesquippedaliophobia is the fear of long words.
I wasn't bright enough to take more than the one.
The span is about 22-24 (double car garage), pitch maybe 8:12.
The first three trusses from the right have the 6" bottom chord and had OSB decking for storage (with a drop down stair between bottom chords,) the rest were like the one on the left with a 2x4 bottom chord and no decking
I've attached a rough sketch, not to scale.
In my workshop (22x30) I put in "W" trusses with 2x6 bottom cord. (10 pitch). I screwed down 5/8" plywood and have a great place for storage.You get out of life what you put into it......minus taxes.
Marv
Thanks.
Awhile ago BH offered the opinion that in most cases, a truss designed to carry storage loads will have the 6" bottom chord, which these do.
The connector plate looked a bit wimpy to me though, so I though i"d see if BH, our resisent truss guru, had some further thoughs
Bob - I suspect that they were designed for storage loads, based on your sketch. But it sure seems odd that they would only do that for the first 3 trusses.
The trusses you saw were most likely designed for light storage - Something on the order of 20 PSF. That's pretty typical in a "storage truss". And that would explain the small plates at the bottom chord joints.
Keep in mind that a truss plate is rated for around 200# per square inch of plate area, on BOTH sides. So technically a big plate isn't called for.
When I do storage trusses, I overplate the bottom chord joint as well as the peak plate. And I use 30 or 40 PSF (instead of 20 PSF) if there's more than 6' of headroom in a storage truss. But that's just personal preference - It's not required.It is an unfortunate fact that we can secure peace only by preparing for war. [John F. Kennedy]
"In my workshop I put in "W" trusses with 2x6 bottom cord.I screwed down 5/8" plywood and have a great place for storage."
Just wanted to mention that using a 2X6 BC isn't enough - The trusses have to be DESIGNED for storage loads as well.Lord, I wish to find you, but spare me from those who have!
