My bathroom is plumbed with black plastic pipe. I’m guessing this is different than white PVC, so what is it? Is it commonly available at the big boxes? If not, can it be glued to PVC?
TIA, Bart
TIA, Bart
It is ABS plastic and it uses a similar, but different cement.
It might depend on your area, but in my both PVC and ABS are commonly available in the home horror stores.
Like Bill wrote, most of the black pipe used in plumbing these days is ABS.
They do sell an ABS/PVC cement. Never used it, but I know plumbers who have and I've never heard them talk nasty about it.
"They do sell an ABS/PVC cement"
They there are too different kinds.
One is a "universal" cement that is suppose to work on either, but only to joint two pieces of the same material.
http://www.oatey.com/apps/catalog/showprod.asp?ctg=1&subctg=1
I think this is the "universal", which means it's good for ABS to ABS or PVC to PVC, but not ABS to PVC:
http://www.oatey.com/apps/catalog/showskus.asp?ctg=1&subctg=1&prodgrpid=1
Isn't this one a transition-type of cement, for joining ABS to PVC? Would this not work:
http://www.oatey.com/apps/catalog/showskus.asp?ctg=1&subctg=1&prodgrpid=166
Still, it shouldn't be used for pressurized supply plumbing, usually just for DWV. Supply side transitions are normally accomplished with a threaded transition, or something similar.
Thanks for the info everybody. Someone over on the John Bridge tile forum had exactly the same question for exactly the same reason. The folks over there said that it is against code in a lot of places to glue PVC to ABS and recommended a coupler instead (I think they called it a Fenco coupler?). I picked one up at the big box, anybody see an issue with doing it that way?
Fernco
Thats fine.
Eric
I saw some 4" plastic pipes on the back of a truck the other day that were a blueish green color. There was also white pvc the same size on the truck. Is the green stuff different for some special application?
That sounds like PVC sewer pipe. But a green dye.
I ran into the same problem six months ago while replacing a fiberglass shower with a custom tile shower. After extensive research, I found that there is no good gluing solution for ABS to PVC. Someone recommended a no-hub coupling, and that has worked for me. Found them at HD. Torque clamps to 60 inch-pounds.
