So I had a tree start to push over a concrete block wall…I removed the tree, but I need to reset about 7 or 8 of the blocks, most of which are still locked in.
I know how to set the blocks, but how do I get the ones loose which are still mortared in place so I can reset them? This wall was built 40 years ago with a block that is now hard (or impossible) to get…
I have used a diamond cutter on my side grinder. I cut mortar out between bricks and it worked very well. Tile setters use these to cut tile.
James
Try a plugging chisel. A good builders supply should have one.
Mike
