Help: Just talked to a daughter w/ a water leak into the basement problem. This is a subsidiary problem. In discussing the source of her water, she mentions her water supply line from the city water line out at the sidewalk. Says it is “Blue PVC.” My antennae went up. (I’m an ant in disguise.) I recall a massive replacement of blue polysomethingorother water supply lines here in Etlanner, Jawja, a few yrs back because the poly was failing.
Does anyone remember what that was and if the replacement at the cost of the pipe supplier program is still goning on? (Of course, someone does, you are all pros – right?) Her house is the right age to have that blue stuff in it.
Don Reinhard
Help: Just talked to a daughter w/ a water leak into the basement problem. This is a subsidiary problem. In discussing the source of her water, she mentions her water supply line from the city water line out at the sidewalk. Says it is "Blue PVC." My antennae went up. (I'm an ant in disguise.) I recall a massive replacement of blue polysomethingorother water supply lines here in Etlanner, Jawja, a few yrs back because the poly was failing.
Does anyone remember what that was and if the replacement at the cost of the pipe supplier program is still goning on? (Of course, someone does, you are all pros - right?) Her house is the right age to have that blue stuff in it.
Don Reinhard
