BORING HOLES IN GLASS
Kivi | Posted in General Discussion on December 14, 2006 08:08am
a glass cutting drill bit. You can find them at hardware stores.
    BillHartmann | Dec 14, 2006 08:19pm | #1
    What kind of glass doors.
    Moder glass doors will have tempered or laminated glass. Most often tempered. And that can't be drilled or cut at all after it have been tempered.
    Hey every group has to have one. And I have been elected to be the one. I should make that my tagline.
    1. Adrian | Dec 14, 2006 08:22pm | #2
      Some glass shops can do it; don't know what they do though.Cabinetmaker/college woodworking instructor. Cape Breton, Nova Scotia.
  2. FHB Editor
    JFink | Dec 14, 2006 08:25pm | #3
    Can we ask....why?
    Justin Fink - FHB Editorial
    Your Friendly Neighborhood Moderator
    1. hasbeen | Dec 14, 2006 10:01pm | #4
      LOL You are so tactful! Boring holes in bottles?Some new home construction technique, I'm sure. <G>
      "Doubt is not a pleasant condition, but certainty is absurd."
      ~ Voltaire
    2. dickIII | Dec 15, 2006 09:37pm | #9
      My neice asked me to bore a hole in a wine bottle, of course I had to empty it first and after emptying it I felt I could do anything so I said yes I would do it for her. She puts a string of colored xmas tree lights inside. It does look rather nice. After posting this, I went on the web and found out about "soft" glass and "hard glass". The hard glass (tempered) can't be drilled and since I don't really plan on doing any, I'm not worrying about it. They could not tell me how to actually drill the hole and that is the reason I posted the msg. here.
      1. FastEddie | Dec 15, 2006 09:40pm | #10
        Buy a glass bit from HD or Lowes.  Looks like an arrowhead.  Drill slowly and with very little pressure.  Make a weird scraping/grinding noise.  Drill slowly and with very little pressure.  If you make a mistake, well there's another full bottle in the house.  Drill slowly and with very little pressure.  A drill press work very well.
        1. Adrian | Dec 15, 2006 10:24pm | #11
          There are a few people saying tempered glass can't be drilled....I thought that too, but there are any number of glass shops now saying they can (google for glass shops that can). I don't know how they do it, but they say they can.
          I also had someone tell me you can score a circle, fill it with lighter fluid or something like that, ignite it, and then you can drill the hole....we couldn't test it, so I don't know if it works or not.Cabinetmaker/college woodworking instructor. Cape Breton, Nova Scotia.
          1. Tom69 | Dec 15, 2006 11:18pm | #12
            I have successfully sandblasted holes in glass but it's best to go at it from both sides, as the eroding sides don't go through exactly square. (obviously you can go only one direction with a bottle) Mask well first. Both the glass and your face. I'm not sure if I have done tempered or not . Try a sample first.Edited 12/15/2006 3:19 pm ET by Tom69
            Edited 12/15/2006 3:21 pm ET by Tom69
            BillHartmann | Dec 15, 2006 11:31pm | #13
            "I also had someone tell me you can score a circle, fill it with lighter fluid or something like that, ignite it, and then you can drill the hole....we couldn't test it, so I don't know if it works or not."Some like that MIGHT work. Don't really know. But if it does what you have done is remove the temper, at least from that section of glass.I did find that place that tempered glass can be drilled, but the probably of sucess is very low."Drilling Tempered Glass - Not RecommendedTempered glass can be drilled, however, breakage may run as high as 80% to 90% depending upon the degree of temper in the glass. We do not recommend trying to drill tempered glass.The manufacturing process of making tempered glass results in the glass having a large amount of stress between various portions of the glass. The stress points might look much like a piece of wood containing lots of "knots", however, there is no outward appearance to indicate the hidden stress. Highly tempered glass will often crack at the stress points near the hole. Since the amount of hidden stress increases with the degree of temper, the success rate of drilling tempered glass reduces with the increase in glass temper.There is no way to know the amount of temper in a piece of tempered glass, so there is no way to evaluate the amount of risk involved in trying to drill it. Therefore, we DO NOT RECOMMEND attempting to drill tempered glass."http://www.diamond-drill-bit-and-tool.com/Diamond-Drill/Default.htm?DD1.htm
          3. Oberon | Dec 17, 2006 03:10am | #16
            You cannot drill tempered glass.  You cannot cut tempered glass.
            It is a physical impossibilty.  It cannot be done because of the nature of the beast.
            Tempering causes a center tension layer and a surrounding compression layer in the glass. When attempting to cut or drill tempered glass you must pierce the temsion layer - and as soon as you do you have a pile of little tiny glass chips on the floor.
            Anyone who claims to have cut tempered glass is no doubt being totally honest in their belief - but they are simply mistaken or misinformed about the glass that they cut - the glass that they cut was not tempered.
            There is no 80% or 90% "failure rate" in cutting tempered glass.  There is a 100% failure rate because tempered glass will ALWAYS break when someone tries to cut it or drill it.
            If a glass shop claims to be able to cut or drill tempered glass then that concerns me because that glass shop is unable to tell the difference between tempered glass and non-tempered glass.
            Also, there is nothing that a homeowner or glass shop can do to remove the temper from a piece of glass.  The only thing that a homeowner or glass shop can do would be to break it.
            Edited 12/16/2006 7:13 pm ET by Oberon
          4. sharpblade | Dec 17, 2006 03:22am | #17
            Thank you. This subject comes up every once in a while and many folks still don't get it.
            For the ones talking about a ~90% failure rate, equivalent to 10% success rate on cutting a piece of tempered glass.  Yeah right, that's comforting.  Maybe the 10% is the margin of  error by the experts in properly identifying a piece as tempered...
          5. Oberon | Dec 17, 2006 04:22am | #18
            you are welcome...and I certainly hope that there are no tempered glass manufacturers working to achieve a 90% success rate(!)
            Considering why we temper glass then that would really be a concern...
            Edited 12/16/2006 8:45 pm ET by Oberon
      2. QCInspector | Dec 16, 2006 03:03am | #14
        http://www.leevalley.com/wood/page.aspx?c=2&p=32277&cat=1,180,42316&ap=1+Use a drill press at slow speed, light pressure, with water from an old cleaning spray bottle to lubricate.
  3. hasbeen | Dec 14, 2006 10:04pm | #5
    If you do it very slowly you can sometimes melt a hole through a bottle with a propane torch. As it softens, you can take a tool of some sort and twist a hole through the glass. You may experience a substantial number of broken bottles.
    I know it works. I did it a few times back around 1973. < G >
    ~ Voltaire
  4. EJCinc | Dec 14, 2006 10:42pm | #6
    I recently had to drill holes through glass tile to mount an elaborate shower head.
    Started the hole with a dremel tool with a little grinding bit.  It made an indent enough so the next bit wouldn't walk.
    Next I used a masonry bit in a normal drill... not hammer drill.  Took a while but it worked and the glass tile did not shatter.
  5. atrident | Dec 14, 2006 11:45pm | #7
    Seen the copper tube and grit also. Try some valve grinding paste .silicon carbide?
  6. Omah | Dec 15, 2006 05:50am | #8
    You can't bore holes in tempered glass at all. the holes have to be there before the piece is tempered. I've never tried bottles but I've bought glass drilling bits at the harware store.
  7. bkhy | Dec 16, 2006 04:18am | #15
    drill it underwater
Kimberley Robles, Decorative Concrete
In this interview, Kimberley talks about the importance of proper training, current concrete trends in the Bay Area, and the history of racist housing policy in San Francisco.
  • Podcast 549: Energy Upgrades, Chimney Inspections, and Questions About a Home You Might Buy
  • Podcast 549: Members-only Aftershow—Patios vs. Decks
  • Podcast 548: PRO TALK With Design/Build Operations Manager Jessica Bishop-Smyser
  • Strategies for Venting a Roof Valley
BOOKS, DVDs, & MERCH
Shop the Store
  • 2023 Tool Guide
    Buy Now
  • Pretty Good House
    Buy Now
    Buy Now
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
