Box-in method for lolly column
| Posted in Construction Techniques on April 20, 2004 06:53am
I need to wrap two lolly columns in finished basement and have never done so.  The method I have in mind is to:
1.  Prefab 3-sided, 1X box to length
2.  Install by shimming inside to column with const. glue and wood shims
3.  Wait for glue to set, box in 4th side, apply trim to top and bottom
As I’ve never done this, would appreciate any suggestions or deviations from my proposed method.
Regards to all
  1. UncleDunc | Apr 20, 2004 06:57pm | #1
    Use foam in a can instead of glue and shims.
    1. dustmonkee | Apr 20, 2004 08:14pm | #3
      Hey, never thought of that.  So, what you're suggesting is to position the 1X post, plumb it, then insert expanding foam to hold?
      regards
  2. michaels | Apr 20, 2004 07:21pm | #2
    You can also wrap with a mosaic tile for a different look . Carpet would also work .
    just some different ideas
    mike
    No good deed goes unpunished
  3. davidmeiland | Apr 20, 2004 09:22pm | #4
    Use c-shaped pipe hangers/straps that will fit around the column, attach some blocking to one or more sides of the column, then screw the box to that.
    1. dustmonkee | Apr 20, 2004 10:07pm | #5
      Outstanding suggestion!  How I've missed these tricks can be explained only by the amount of paint chips I ingested as a child!
      Great tip,
      the lead-based carpenter
      1. Wylcoyote | Apr 20, 2004 10:29pm | #6
        Some lolly column's have an adjustment bolt at the top - you might need to build in a little hinged door into the cover frame in order to access the bolt (if the columns are jacking up sinking floor joists)
      2. davidmeiland | Apr 20, 2004 10:57pm | #7
        I try to have at least one good idea every several years. The rest of the time I just fumble along.... hoping for a clue...
  4. MojoMan | Apr 21, 2004 04:22am | #8
    Your plan sounds fine and the suggestion to use foam makes it even better. Here's one more thought. I'm currently working in a basement where lally columns support large ( about 8x12) beams. The beams were furred out more for wires, pipes, drywall, etc. so they were anout 14" wide when finished. The columns were boxed inside 14 x 14 frame and drywall square columns. This is a big basement so the wasted space was not a big issue. So now, rather than skinny columns or boxes, there are nice, substantial structures that flow neatly from the beam soffits. The scale of them has a nice visual effect.
    Al Mollitor, Sharon MA
