Breaking thru Fieldstone Foundation
RonMag | Posted in Construction Techniques on October 2, 2006 04:05am
Looking for advice on easiest, least back-breaking way to open a doorway in a fieldstone foundation.
Currently in the process of adding a room with full basement to back of house and old foundation wall will now be inside wall of new basement.
I want to have access between old and new basements so need to bust open a doorway.
  1. inperfectionist | Oct 03, 2006 01:27am | #1
    Have you already excavated and exposed the wall?? How big are the stones?? You want to use what was the outside of the stone as an exposed wall 'cause you like the look??
    Usually the problem isn't making the doorway, it is usually the whole wall wants to come down pretty much by itself. If you have any doubts, install some shoring posts under the floor of the house in case she "gives way". You can usually take apart an old fieldstone foundation with a 2 lb hammer and chisel. If the stones are big and you want them out it will be easier before you frame the addition.
    Might be a good time to meet a mason if you don't already know one.
    H
Hole Saws That Are a Cut Above
The Spyder carbide-tipped hole saws cut quickly with a quick-release arbor that makes it easy to remove the core.
  • Podcast 549: Energy Upgrades, Chimney Inspections, and Questions About a Home You Might Buy
  • Podcast 549: Members-only Aftershow—Patios vs. Decks
  • Podcast 548: PRO TALK With Design/Build Operations Manager Jessica Bishop-Smyser
  • Strategies for Venting a Roof Valley
BOOKS, DVDs, & MERCH
Shop the Store
  • Pretty Good House
    Buy Now
  • 2023 Tool Guide
    Buy Now
    Buy Now
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
