Brick – Deck – Stucco flash details
I’ve attached 2 high quality images and 2 resized small but recognizable images.
The brick interfaces with the deck and in the future a stucco wall. I am having the brick protrude from the stucco wall face by 3/4″ to accommodate the thickness of the stucco.
I am not sure how to flash this from the stucco/brick side…
I think I should counter flash onto the decking flashing for the stucco part and then have the flash cut to sit under the brick. Then I think I need a 2nd piece of flash that overlaps.
I’ve attached a picture that shows my two piece flashing approach. Any better ideas? I also think I’ll need to caulk under the first piece of counter flash to prevent wind driven water from going uphill and then down the corner.
Any thoughts/help very appreciated.
Well I went with my approach. Hopefully it is good enough.
I am still interested to hear if there are better ideas or if I screwed up.
Thanks again.
