Broken garage door window
notatexan | Posted in General Discussion on July 24, 2008 04:12am
Due to a couple of related events I broke one the windows in my new garage door in the house I just put on the market.  It is a simple un-insulated metal door.
I can’t figure out how to remove the trim, replace the glass, and pop it back in.  Is there a secret to this?  The trim is not glued except at the corners.  The only thing I can think of is the vinyl trim is two halves and snaps together.
Needed some advice before I brake something else or call the door guy back.
Jim
    xxPaulCPxx | Jul 24, 2008 04:19pm | #1
    When I broke the glass on mine, it was a plastic frame that snapped together with another frame on other side of the door.  U needed a screwdriver to pry it apart.
    Also a CRX fanatic!
    Save the Whales! and Guns!
    1. notatexan | Jul 24, 2008 04:35pm | #3
      I think you are right.  It's got to be two piece.
      I lost sleep last night thinking about it.
  2. Steinmetz | Jul 24, 2008 04:20pm | #2
    It might be rubber and the gasket can be released with a lubricant (such as kerosene,)along with a plastic or wooden pry (Not a metal screwdriver)
    Edited 7/24/2008 9:26 am ET by Steinmetz
Hole Saws That Are a Cut Above
The Spyder carbide-tipped hole saws cut quickly with a quick-release arbor that makes it easy to remove the core.
  • Podcast 549: Energy Upgrades, Chimney Inspections, and Questions About a Home You Might Buy
  • Podcast 549: Members-only Aftershow—Patios vs. Decks
  • Podcast 548: PRO TALK With Design/Build Operations Manager Jessica Bishop-Smyser
  • Strategies for Venting a Roof Valley
BOOKS, DVDs, & MERCH
Shop the Store
  • 2023 Tool Guide
    Buy Now
    Buy Now
  • Pretty Good House
    Buy Now
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
