Built in bench from stock cabinets
billmeister | Posted in General Discussion on April 2, 2006 06:37am
I’m in the process of reworking a side entrance into a mudroom.  The finishes will be slate flooring with beadboard wainscotting.  I would like to incorporate a built in bench:  I want to take a 12″ wall cabinet (used over refrigerators) and set it on a 4″ base.  Then set a granite top on it, and finish the walls with bead board.
Anybody done this before?  Do you forsee any issues?
Bill
  1. calvin | Apr 02, 2006 06:42pm | #1
    Here's a recent job from one of the guys.  For a little inspiration.
    http://forums.taunton.com/n/mb/message.asp?webtag=tp-breaktime&msg=71826.1
    Quittin' Time
  2. piko | Apr 02, 2006 07:20pm | #2
    Simple procedure, really, and a good way to go. I'd suggest that the cabs might get kicked somewhat and maybe an extra coat of urethane to protect if nec. But I wonder if you were thinking of doing the bead board after, as your post reads, cuz it'd be better to put it in first so that you won't have to patch if the bech gets removed.
    All the best...
    To those who know - this may be obvious. To those who don't - I hope I've helped.
    1. KirkG | Apr 02, 2006 11:19pm | #3
      I think the granite would not be a good choice for the bench. Too cold and if a hard object is "dumped" it could crack.
Mortar for Old Masonry
