Built in Compost chute
xxPaulCPxx | Posted in General Discussion on April 28, 2009 07:11am
I’ve been thinking about composting kitchen scraps, and I want to build a chute directly from inside the kitchen directly to the compost pile.  The two would be connected by a 3″ or 4″ diameter ABS pipe at a 45 degree angle sloping down
From inside you would pull out a 1′ long sealed plug (think teller delivery tube)that would lead directly to a compost pile under the herb garden.  When its time to scrape the dishes, instead of doing it into the garbage disposal you can do it directly into the compost pile.  The plug would have a rubber seal that would push any residue on the walls down into the pile when the plug was replaced.
Obviously, this would entail building a compost pile next to the house.  I would seal the wall there with I&WS.
The roof of the pile would be an herb garden.  Underneith would be the compost box.  For this I imagine a 3′ tall 2’x6′ box for the scraps to breakdown.  I was thinking a pair of auger blades could periodicly stir the mix down the box to keep it from piling up under the fed tube, feeding it down to an exit point where it could be scooped out for garden and lawn use.
Any thoughts on this?
Tu stultus es
Also a CRX fanatic!
Look, just send me to my drawer.  This whole talking-to-you thing is like double punishment.
Edited 4/28/2009 6:25 pm by xxPaulCPxx
    Ted W. | Apr 28, 2009 07:21pm | #1
    Sounds like a good idea. I'd go with the 4" to be on the safe side. Also, it seems kind of tricky scraping the waste into a 4" round opening. Maybe needs some sort of funnel or something, which you can rinse with water. I think some thought has to go into the design, but definately a worth while idea.
    ~ Ted W ~
    Cheap Tools! - MyToolbox.net
    Meet me at House & Builder!
  2. husbandman | Apr 28, 2009 07:52pm | #2
    Sounds like a lot of added work just to take out the compost.
      xxPaulCPxx | Apr 28, 2009 08:02pm | #4
      That's the thing, I do all this work so that composing is eeeeaaaaassssyyyy.
      My wife would NEVER put up with piling up a whole load of potentially rotting vegatables in the kitchen then taking them out back to stuff into a box.  Too much hassle.
      Open tube, insert salad cuttings, close tube... I could sell her on that!
      Tu stultus esRebuilding my home in Cypress, CAAlso a CRX fanatic!
      1. ronbudgell | Apr 28, 2009 10:46pm | #19
        Paul,
        Why settle for just kitchen scraps - you can save it all:
        http://www.clivusmultrum.com/products_basic.shtml
        You open a door at the bottom of these things once in a while and shovel out a wheelbarrow load of humus. You don't really need to throw away anything organic
        Ron.
          xxPaulCPxx | Apr 28, 2009 10:52pm | #21
          ...and shovel out a wheelbarrow load of humus.
          Hey, I like a good galic garbonzo bean dip as much as the next guy, but there is no way I'd be able to eat a wheelbarrow full of the stuff.
      2. husbandman | Apr 29, 2009 03:39am | #40
        I understand the situation now!As the proud owner of several tons of compost, made using at least three different methods, I salute your efforts!Un-asked-for-compost-advice: Get red wiggler worms. The little critters truly are too-good-to-be-true.If you want to know more you can google it or ask and I'll tell.Or drop by and I'll give you a bucket full of vermiculture. "A short drive to Colorado is just a normal part of a kitchen remodel, dear." : )
          xxPaulCPxx | Apr 29, 2009 04:39am | #44
          I'm making a trip tommorrow to a composting shop to talk to people there about this.  It could be what I need is vermiculture rather than traditional composting piles.  From looking at the vermi setups, it might even be easier to set up!
          1. husbandman | Apr 29, 2009 05:28am | #49
            A composting shop! That's hilarious!I have to drive 50 miles one way to get to a garden shop! Of course, 50 miles takes 45 minutes.I'm afraid we really live in different worlds. <G>
            xxPaulCPxx | Apr 29, 2009 10:50pm | #62
            I used to live in rural Illinois, so I well remember the "miles=minutes" rule.
            Just got back from the composting store (composters.com) and had a good chat with Liz there.  Showed her the concept, and we talked about vermiculture.
            So worms are where I'm heading to now.  I want to make the changeover system a little easier than I'm seeing in the nested tray setups I'm seeing now.  I'd like to be able to slide the bottom tray out for changing then replace it on top of the stack when empty, but all the systems I've seen require you to remove all of the top shelves to get to the bottom.
            Looks like I'd have to rig a lift to raise the other decks to remove the lowest one.
            How high do you stack gunk in the top tray before you move it down?
          3. husbandman | Apr 30, 2009 03:24am | #69
            I don't use any commercial products.There's a book "Worms Eat My Garbage" that could educate you a little more. There are plans for boxes you can build for your worms.I have worms outside in compost piles. And I have worms in a 3x6 table box sort of thing I built out of scrap form lumber. I put wheels on it so I can roll it out of the way in my shop. The table top/box is the depth of a 2x8. Except for large extra amounts during harvest/preservation season, the rest of the year's kitchen garbage all goes into the one box. The only thing I add besides kitchen waste is shredded newspaper and water.The worms decide where they want to be in the box. They'll totally devour certain things quickly, other things take longer. If part of the box gets dry they move over the more moist area until I water the box again.It's extremely simple once you figure out the environment they need.
            xxPaulCPxx | Apr 30, 2009 09:13am | #72
            Ahhh, there is something new I've found - the Flow Through vermiculture.  It's just a barrel with a grate at the bottom, no moving bins in the stack.  You just keep filling from the top, and when you get full you start pulling from the bottom (upside down rake) - it will level itself out.
            This simplified things greatly!
          5. husbandman | Apr 30, 2009 05:27pm | #75
            If you're going to garden, you'll be glad you started in with the worms.Good luck!
    IMERC | Apr 28, 2009 07:59pm | #3
    seperate the disposal from the gray line...
    outlet that to the compost pile...
    WOW!!! What a Ride!
      xxPaulCPxx | Apr 28, 2009 08:06pm | #6
      I was initially thinking that, but from my readings on composting it sounded like you can drown your pile with too much water (that would lead to rotting), which a garbage disposal needs to run food through.
        IMERC | Apr 28, 2009 08:12pm | #10
        seperation trap...
        WOW!!! What a Ride!
          xxPaulCPxx | Apr 28, 2009 08:15pm | #11
          Huh?
            IMERC | Apr 28, 2009 10:11pm | #17
            like a sand trap or a grease filter....
            send the water to the flowers and the solids to the pit...
            WOW!!! What a Ride!
          2. DanH | Apr 28, 2009 10:12pm | #18
            And catch the golf balls.
            IMERC | Apr 29, 2009 02:30am | #36
            gotta try that...
            a box of golf balls run thru the a disposer...
            WOW!!! What a Ride!
          4. MikeHennessy | Apr 29, 2009 02:45pm | #53
            "a box of golf balls run thru the a disposer..."
            LOL! -- kinda like this  http://www.youtube.com/watch?v=MC8Zvl-8ziA
            Mike HennessyPittsburgh, PA
            PeteDraganic | Apr 29, 2009 09:52pm | #56
            I gotta say that the video makes me want to buy that blender.
            I refuse to accept that there are limitations to what we can accomplish.        Pete Draganic
            Take life as a test and shoot for a better score each day.          Matt Garcia
          6. MikeHennessy | Apr 29, 2009 09:58pm | #57
            They have a whole series showing that guy "blending" various unlikely bits. Kind of entertaining.
          7. User avater
            Dam_inspector | Apr 29, 2009 10:33pm | #60
            The blended ipod was good.
          8. User avater
            PeteDraganic | Apr 29, 2009 11:22pm | #63
            that is one B.A. blender.
          9. DanH | Apr 29, 2009 11:42pm | #64
            Kinda like a Bass-o-matic?
          10. MikeHennessy | Apr 30, 2009 02:28pm | #73
            "Kinda like a Bass-o-matic?"
            I think that's where they got the idea.
            One of my all-time favorites.
            Mike HennessyPittsburgh, PAEverything fits, until you put glue on it.
            Edited 4/30/2009 7:34 am ET by MikeHennessy
          11. User avater
            IMERC | Apr 30, 2009 12:35am | #66
            eons ago I took a golf ball apart it it was mostly a bazillion miles of rubber band under compression...
            sortta envisioned all that getting loose all at once....
            kinda like a major all at once "sproing"....
            darn...
            WOW!!! What a Ride!
          12. MikeHennessy | Apr 30, 2009 02:33pm | #74
            "bazillion miles of rubber band under compression"
            Yeah, that was always a fun afternoon project as a kid. Find a couple old golf balls and wrap the whole freakin' neighborhood in rubber bands. For a 10yr old, that's FUN!
            Nowadays, I think most golf balls are solid core, tho.Mike HennessyPittsburgh, PAEverything fits, until you put glue on it.
    2. jimcco | Apr 29, 2009 11:56pm | #65
      That sounds like a really great idea; but our county (Tulsa,Ok) does not reccognize "gray water" any liquid originating in the house has to go to the sewer or septic tank.
      I think they are just trying to sell more water.
  4. DanH | Apr 28, 2009 08:04pm | #5
    I'm thinking you'd have a lot of trouble with scraps sticking to the side of the tube.
      xxPaulCPxx | Apr 28, 2009 08:08pm | #7
      If the walls of the tube are smooth ABS, and the plug has a couple of rubber rings that seal against the walls, it would push the remanents forward and down every time the plug was replaced
      1. DanH | Apr 28, 2009 08:11pm | #8
        Yeah, but you'd probably end up with a lot of stuff in the tube, waiting for the next push. May be some trouble with it plugging.
          xxPaulCPxx | Apr 28, 2009 08:19pm | #12
          The 12" plug would actually run the full length of the tube - the pile would be on the other side of the wall.  The plug would push everything through until it dropped off the edge of the tube.
          I hear you about trying it out first before cutting a hole!  I plan on building a full mock up of this and the grey water sink so I can get buy in from the wife.
          1. DanH | Apr 28, 2009 08:21pm | #13
            Heck, why not just create a southern compost chute -- cut a hole in the floor and let the raccoons haul off the waste?
            xxPaulCPxx | Apr 28, 2009 08:38pm | #14
            Only if they plan on pooping in my flower bushes!
          3. mrsludge | Apr 28, 2009 10:01pm | #16
            Not to mention that a "way out" is also a "way in" potentially. Would make for a funny movie scene of homeowner doing battle with raccoon/rat/possum in the comfort of their kitchen.
            xxPaulCPxx | Apr 28, 2009 11:13pm | #25
            Potentially yes.  With the plug in place though, there would be no purchase in the tube.  The plug would end flush or protrude slightly to push out scraps.
            But keeping the compost box sealed to keep it from being a nest is of couse something to watch for too.  Maybe I can have on of the nearly tame coyotes in my neighborhood move in there first!
      2. DanH | Apr 28, 2009 08:11pm | #9
        (You might want to experiment with a prototype before cutting a hole in the wall.)
  5. MikeSmith | Apr 28, 2009 09:57pm | #15
    my thoughts ?
      this  is  your  basic " bad  idea "
      xxPaulCPxx | Apr 28, 2009 10:57pm | #23
      *sigh*... here is the part where I - again - beg Mike for more of his thoughts beyond the cryptic one liner...
      Please Mike, I'd paypal you a penny for the rest of your thoughts if it didn't cost $2.85 to do so :)
      Bad how?
      1. MikeSmith | Apr 28, 2009 11:39pm | #27
        paul....  we  compost  everything that  will  rot
        anything  that  won't  rot  goes  in the compactor
        we've  had  a  compost  pile  for the  36  years  we've  been married
        so...
        right  outside  your  house  you  want to  build  a compost  pile,  separated  by  Ice  &  water  and  linked  by  a  pipe....hmmm
        at  some  stage  in  the  cycle  the  compost  stinks
        it  attracts  animals   (  benefit  ..  they  turn  over  your  pile  for  you )
        we  use  a  container with  a  seal  on  it  ... probably about  1  1/2  gal
        it  usually  holds  enough  so  it  only  has  to  be  emptied  about  2x  a week..   everything  from  coffee  grounds,  to  chicken  carcasses   to  oyster/ quahog  shells  , vegetable pealings  and   those  unidentifiable  containers  from  the  back  of  the  fridge
        so....  it  works  great..  we  have  lot's  of  worms  in our  pile
        but:
         it  stinks
        it  attracts  animals
        it  ( especially  the pipe )  is  unsanitary
        that  kind  of  activity  next  to your  house is  not  a good  idea
        get  a  better  compost  container  and  do  the  perp  walk
          xxPaulCPxx | Apr 28, 2009 11:53pm | #28
          See, that's what I needed to know!
            xxPaulCPxx | Apr 28, 2009 11:55pm | #29
            This is a drawing of what I was thinking, except the plug would go all the way to the end of the chute.
          2. JohnT8 | Apr 30, 2009 07:19pm | #77
            OK, I haven't read this entire thread yet.  has it reached the Rube Goldberg stage yet?
            "In three words I can sum up everything I've learned about life: It goes on."
            -- Robert Frost
            Edited 4/30/2009 12:32 pm by JohnT8
            xxPaulCPxx | Apr 30, 2009 07:32pm | #79
            Depends on if you include the trebuchet on the neighbors roof or not.
          4. AitchKay | May 02, 2009 03:22am | #95
            Funny thing is, by the first time you mentioned a trebuchet, I'd already thought of it, and pictured that system in my mind.So with two votes for it already, I think we should take a vote right now of the broader population.What say, Guys? Your choices are:1) The Slimy Chute to a heap right outside your kitchen window,2) The Garbage Disposal pre-mulching/nutrient-rich-irrigation system,3) The Extremely-Manly Texas-Style Garbage-Hurling Trebuchet.Myself, I'm thinking it's a dead heat between #2 and #3, with #1 a way-distant third place.But let's tally the votes from the population at large!AitchKay
        2. DanH | Apr 29, 2009 12:58am | #30
          Darn! You spoiled our fun!
          xxPaulCPxx | Apr 29, 2009 01:22am | #31
          It sounds like most of those issues you point out could be mitigated fairly easily:
          Smell can be managed through ventalation.  Cool air in the bottom, hot air out the top though a vent tube.
          Animals can be kept out.  On the other side of the wall there is a whole room full of food that we have yet to see a rat in, I think you could do the same here.  The ventalation will help keep it from smelling tasty too.
          As far as sanitation goes, the tube is next to the sink, with access to soap, water, and cleaning tools.  We're not going to eat off it, but otherwise it should be sanitary.
          1. betterbuiltnyc | Apr 29, 2009 01:28am | #32
            Skip the herb garden on top--too fancy and too complicated.I recommend these to urban composters--it's sealed so smells don't bother neighbors, and it is designed to not need emptying--the critters carry away the debris. I've got one inside a raised bed.Set up your chute so waste goes in, and seal the connection. Now you don't have a giant sponge next to the house.
            xxPaulCPxx | Apr 29, 2009 01:38am | #34
            I missed what you were poining to in your post.
            The herb garden is one of the reasons why I'm doing this.  That will be there, regardless if I make a composter underneith or not.
            PeteDraganic | Apr 29, 2009 02:00am | #35
            what purpose would the herb garden serve over the copost bin? just a lid?
            xxPaulCPxx | Apr 29, 2009 02:40am | #37
            The purpose of the herb garden is to season food!
            It's elevated for ease of access and so I can see what I can use from the kitchen window.  Being able to use the space underneith is just gravy.  Stinky, nutirent rich gravy.
            IMERC | Apr 29, 2009 02:58am | #38
            or make for the munchies???
            WOW!!! What a Ride!
            xxPaulCPxx | Apr 29, 2009 04:50am | #47
            That's the one in back ;)
          7. betterbuiltnyc | Apr 29, 2009 03:44am | #41
            Sorry...forgot to link.http://solarcone.net/system/index.php
          8. levelone | Apr 29, 2009 04:21am | #42
            I'm not going to comment on the advisability of the compost next to the house and the critters, but as to the pipe, I have a thought or two.
            If you think of the pipe as a hydraulic cylinder, the plunger being tight fitting and having o-ring seals, there should be no food residue left in the pipe.  You could machine a piece of acrylic, UHMW, HDPE or other plastic with a couple of grooves, fit them with o-rings, attach a rod/push stick to the center of the plunger.
            You could leave the plunger at the compost end of the pipe when not in use and have a cover/cap inside the house.  To use, remove the inside cover, pull the rod w/ plunger into the house, insert food into pipe, insert plunger into pipe, push out, reinstall inside cap.
            Might need to chamfer the ends of the pipe for easy punger entry and apply a little oil of some type for lubrication.  Should work great.
          9. User avater
            xxPaulCPxx | Apr 29, 2009 04:35am | #43
            Yes, that is exactly what I was thinking of.
          10. User avater
            xxPaulCPxx | Apr 29, 2009 04:49am | #46
            That is an interesing device, thanks for that link!
          11. smslaw | Apr 29, 2009 10:24pm | #58
            There must be some way to introduce fire to this already complicated concept.  Some sort of flamethrower to keep the tube sanitized.
          12. User avater
            IMERC | Apr 30, 2009 12:38am | #67
            fuel atomizer blower unit hooked in via a soil wye....
            WOW!!! What a Ride!
          13. PeteBradley | Apr 29, 2009 03:38am | #39
            >Smell can be managed through ventalation...Animals can be kept out.Are those statements from experience? Mabe your area is different, but I'd rewrite your statements as: "most of the time you can keep the smell to a minimum if you don't throw in all the proteins that hardcore composters like Mike do";and:"animals in a certain size range can be kept out, but the very big and the very small are going to get in if they want to, and the sizes in the middle are still going to come and investigate"Pete
          14. User avater
            xxPaulCPxx | Apr 29, 2009 04:48am | #45
            Where I live, here, has no bears, lions, or deer.  We do have coyote, opossum, and a rare raccoon.  If you keep a sharp eye, you can see the rats running the power lines.
            This isn't going to be a plywood box behind the shed next to the woods.  This might be concrete and steel - I don't know as I haven't gotten far enough into choosing the building materials.  You are not going to look at it and think "Compost!"
          15. smslaw | Apr 29, 2009 10:27pm | #59
            Not now, but wait'll the word gets out.
            We might look at it and say: This guy has way too much free time:-)
          16. User avater
            xxPaulCPxx | Apr 29, 2009 10:41pm | #61
            You wouldn't be the first to think that!
          17. wrudiger | Apr 30, 2009 06:17am | #70
            Includes a ~3 gal. bucket w/handle, rubber gasket to seal in oders.  Takes us about a week to fill ours unless we've just done a harvest and have a lot of scrap.  Ours is undermounted & right next to the main sink.  Carry the bucket out to your bin away from the house.
            We have 30" counters so it really has no impact on counter space.  Commercial quality, no penetrations in the wall, big hole (easy to hit when flinging waste).  Only downside is it's kinda pricy.  Franke Waste Bin AE-81 or AE-E17
          18. mackzully | Apr 30, 2009 08:42pm | #85
            Wow, super cool, but is it, ummm, worth the $300? Is it anything more than a nice SS bucket, does it have sealing o-rings or a nanotech coating to clean itself, etc?Great idea regardless, I've got a corner next to the sink that might be perfect for something like that.Z
          19. wrudiger | May 01, 2009 06:43am | #93
            It's got sealing o-rings & a SS lid.  Very easy to clean.  I've got the plastic bucket - bigger & cheaper.  Yea, to finish off a nice remodel and leave a stinky too-small tupperware on the counter, or a bigger bucket under the sink - both a real hassle to add scraps to - just didn't seem right.  So for me the value was totally there.  Probably closer to $250 when I got it.
            Edited 4/30/2009 11:44 pm by wrudiger
          20. User avater
            Sphere | May 02, 2009 02:39am | #94
            Generally, adding meat or animal ( dog , cat ) poo to compost is pretty much frowned on.  That is what will attract unwanted critters in the compost bin.
            I specifically hauled 40 gallons of crab shells way up away from the house in NC, when my bud brought live crabs from Va. He asked why I was going so far up the mountain ( in the truck) and  i said "Bears"
            Not an hour later, we drove back up and saw a huge bear just chomping away in the headlights.
            Around here if you toss meat or fish out, it will attract skunks, possums, coyotes, and god knows what else. I guess you can get away with it in R.I.Spheramid Enterprises Architectural Woodworks
          21. MikeSmith | May 02, 2009 03:29am | #96
            skunks, possum, raccoons, neighborhood dogs, cats.....
            you mean the workers in the vineyard ?
            who do you think turns my compost pile over ?
            yesterday i went to the beach, got 5bushels of seaweed, put it on the compost pile , piled some dirt on it..
            this morning , perfectly turned and aereated
            new compost...i bury it, the workers dig it up and toss the pile, everybody's happyMike Hussein Smith Rhode Island : Design / Build / Repair / Restore
          22. User avater
            Sphere | May 02, 2009 03:32am | #97
            I'd like a pile of seaweed, but the walk to the beach is a killer.Spheramid Enterprises Architectural Woodworks
          23. User avater
            IMERC | Apr 30, 2009 12:40am | #68
            burial vault in the ground....
            screw augers employed to mix and lift the materials...
            WOW!!! What a Ride!
        4. JohnT8 | Apr 30, 2009 07:15pm | #76
          Maybe he could set it up with an underground conveyor belt that trasports the stuff to the back of the yard and then gets augered onto the top of the compost pile :)
          -- Robert Frost
            IMERC | Apr 30, 2009 07:50pm | #80
            potatoe cannon set up....
            with foot pedal...
            WOW!!! What a Ride!
    Dam_inspector | Apr 28, 2009 10:47pm | #20
    I'd build a compost cannon. Much more entertaining.
      xxPaulCPxx | Apr 28, 2009 10:53pm | #22
      While tempting, It would be a pain getting my fresh compost all the way from my neighbors roof to my garden.
      Unless I built a compost trebuchet on his roof... hmm...
        Dam_inspector | Apr 28, 2009 11:01pm | #24
        Well, there ya go!
  7. Hiker | Apr 28, 2009 11:14pm | #26
    Your part of the world may be prettier than my part, but around here, the critters like partaking in the compost bin.  I could see a rat hanging out a the discharge zone waiting for the next course and maybe getting aggressive.  Sometimes the compost can go anaerobic-not so pretty either.
    Bruce
  8. User avater
    PeteDraganic | Apr 29, 2009 01:35am | #33
    this sounds like a horrible idea. Food will always stick to the inside of the tube and will eventually rot and mold. Adding water to rinse will probably only make things worse. Smells, if they develop, that close to the house will be a big problem too.
    If you want to compost, then you gotta take the stuff out the old fashioned way, imo.
  9. AitchKay | Apr 29, 2009 05:13am | #48
    levelone said,
    "I'm not going to comment on the advisability of the compost next to the house and the critters, but as to the pipe, I have a thought or two.”
    Another plus that the garbage-disposal system has is that it lets you locate your compost pile further from the house.
    And here’s some further tweaking: support two screened frames above the drain slab, one under the PVC outlet, and one off to the side, but still over the slab. When the first is semi-full, switch them out, set the full off to drain/dry a bit, then dump it onto your adjacent compost pile. Repeat as necessary.
    and,
    ronbudgell said,
    “Paul,
    Ron.”
    I installed a Clivus Multrum back in the 70s. They’re awesome! Interesting time-delay switch, designed so that you don’t scoop out any humus (sorry, no hummus!) before it’s time: a sheet of plywood. When it rots out, the soil behind it is ready.
    The CM is designed to live in your basement. The toilet is located above the end farthest from the cleanout, and you can mount a serious, porthole-latch-type lid over a cutout in your kitchen counter, further downstream towards the cleanout, if your floor plan works out right.
    Several months after installation, I was working up on the roof, and decided to stick my head into the “chimney.” It smelled mostly like the grass clippings they had recently thrown in -- you have to balance the moisture content. Leaves are good, too.
    They had a big open house to celebrate the installation, and there was a guest book in the bathroom. Just sign in, then make a check mark in the appropriate column -- the one headed #1, or the one headed #2.
    AitchKay
  10. mike_maines | Apr 29, 2009 05:33am | #50
    Paul, I think it's a good idea, especially if you eat mostly vegetarian.
    DW and I have a small deck about 4' above grade right off the kitchen, and an open compost pile off the deck.  We put food scraps and unbleached (used) paper towels in a tupperware container on the counter.  The container isn't very big, so at least once a day it gets emptied.  I love to empty it, and tell DW I'm "feeding the compost pile."  The tupperware container gets rinsed out after every "drop" and washed with soap once or twice a week.  It never stinks or gets moldy.
    There are two keys to our system.  One, be liberal with the paper towels and other "brown" matter.  The carbon in brown matter absorbs the ammonia that results from nitrogenous material rotting.  Our pile never stinks.  Seriously.  And it breaks down in about 6 months into usable compost.  Squirrels aerate the pile when we throw squash seeds or stale bread into it.  Otherwise animals leave it alone.  They don't like rotting vegetables any more than we do.
    The other key is that the small amount of animal-based waste we generate goes into our compost tumbler.  The lobster shells I dumped in the tumbler in the fall are gone now.  Animals don't get into it.  Racoons probably could if they tried, but they haven't yet.
    A side benefit to this, and our city's great single-container recycling program, is that we can go two or three weeks without emptying the trash can that fits under the sink.  It never stinks because we rinse any meat containers.  One bag of trash every couple of weeks, and stink-free compost.  If everybody did that there wouldn't be a landfill problem.  I can't believe the food waste people throw away.  That's free fertilizer!
    1. fingersandtoes | Apr 29, 2009 07:29am | #52
      6 months! You should mess with your compost more. Mine is done in 6 weeks, but then I am always fiddling with it.  A note on the Red Wigglers someone mentioned: Although they do speed up decomposition a lot, if you live in the country, you should think twice about introducing them to areas they are not native to.
      1. mike_maines | Apr 29, 2009 04:09pm | #54
        Yeah, I don't like fiddling with it, I just like to feed it and forget it.
        Good point on the red wrigglers, I've heard that's a problem north of here.  I live in the city and just let the native worms do their thing anyway.
    2. JohnT8 | Apr 30, 2009 07:26pm | #78
      Mike, you're starting to sound like an ad for Organic Gardening and Mother Earth News mags all rolled into one.  ;)
      -- Robert Frost
      1. mike_maines | Apr 30, 2009 08:05pm | #81
        LOL
        My other favorite magazines!
        1. JohnT8 | Apr 30, 2009 08:13pm | #82
          Issue or two back, MEN had an interesting article on some folks in the city who had turned their little lot into a super garden.  Looked like a lotta dang work, but was neat to see.jt8
          -- Robert Frost
          1. mike_maines | Apr 30, 2009 08:26pm | #83
            The ones in Ohio?  It was funny, my wife had just been to the same city to visit her sister the weekend before we got the magazine, and they had walked by the folks in the article and talked to them.
            These folks are really into it: http://urbanhomestead.org/journal/
          2. JohnT8 | Apr 30, 2009 08:36pm | #84
            This might be it:
            http://www.motherearthnews.com/Modern-Homesteading/Amazing-Urban-Homestead-Dervaes.aspx
            -- Robert Frost
          3. JohnT8 | Apr 30, 2009 09:08pm | #86
            That may be the same folks in your link.
            -- Robert Frost
          4. mike_maines | Apr 30, 2009 09:58pm | #87
            'tis
  11. Waters | Apr 29, 2009 05:38am | #51
    there was a sidebar in the magazine I remember--the chute went thru the counter and out into a compartment that held a bin--kind of like one of those door-on-each-side firewood access panels you see.
    So it didn't go directly into a compost pile per se, but into a bin that you could then take TO the compost pile easily.
    All was easily cleaned from inside the compartment--from outside.
  12. User avater
    popawheelie | Apr 29, 2009 06:22pm | #55
    We compost into a large tupperware that sits on the contertop.
    Thinking about it, you could rinse the chute with your faucet sprayer when it gets dirty.
    Maybe a rod with a brush on it for when you want to scrub it. Kind of like a rod and brush for a gun barrel.
    I do all the taking out and cleaning of the compost tub. My family won't do it.
    I figure it gets me out of the house and into the gerden so it is really a good thing.
    I do all the gardening as well.
    I did a compost chute for my mom a long time ago. I ran the line from the garbage disposal out to a bucket in a small shed.
    The only problem was she would forget to empty the bucket. What a mess. My brother took it out.
    "There are three kinds of men: The one that learns by reading, the few who learn by observation and the rest of them have to pee on the electric fence for themselves."
    Will Rogers
    Edited 4/29/2009 11:29 am ET by popawheelie
  13. oldbeachbum | Apr 30, 2009 08:57am | #71
    ..or forego all the hardware & paraphernalia........
    ........................that's what kids are for (the original TV remote)............kid, bucket, rake/shovel....go play
    :0)
    ...The unspoken word is capital. We can invest it or we can squander it.  -Mark Twain...Be kind to your children....they will choose your nursing home....aim low boys, they're ridin' shetland ponies !!
  14. KaneoheBay | Apr 30, 2009 10:18pm | #88
    Re: Slope of tube.
    What is the angle of repose for garbage scraps? If it's less than 45 degrees, then the scraps won't slide down as easily as you envision. Clogging will result.
      xxPaulCPxx | Apr 30, 2009 10:51pm | #89
      The rubber ringed plug will squeegee it forward.
        IMERC | Apr 30, 2009 11:55pm | #90
        push that rubber plug with 300psi at 125cfm...
        it won't clog...
        WOW!!! What a Ride!
          xxPaulCPxx | May 01, 2009 12:09am | #91
          Actually, I was considering shaped charges.  Helps break down the food and reduces clogs.
            IMERC | May 01, 2009 01:04am | #92
            true...
            but we don't want to incinerate the compost...
            WOW!!! What a Ride!
  15. Katherine_Cottage | Apr 29, 2011 05:39pm | #98
    Composting chute for kitchen
    I'm wondering what you decided to do with your compost chute, PaulCP. It looks like it's been a couple years since you posted this query.
    We are building a cottage in our backyard and want to make it easy to compost and maximize counter space .  We'd like a chute that empties from the counter area to a bin outside the kitchen.
    The contractor is willing to go along with us, but we can't quite figure out how to make a smooth, watertight chute that is easy to clean.  (We thought we could spray water down the chute to rinse it.)  We're considering ABS pipe...maybe a toilet flange?
    I found this cool system called the Enviro-Trash Clean chute, but it's $350!
    Is there a way that jettisons the food scraps out of the kitchen but doesn't get smelly?
    1. calvin | Apr 29, 2011 06:48pm | #99
      Here in our humble wooded home.........
      we have a bucket under the sink.
      Sure, every couple days I take it the 200 ft to the compost pile (no twirling bin-unneeded when you mix brown (dead) with green (fresh).)
      No smell (unless you forget) and easy.  If you dump it out the house, where do you let it plop (unspread in a pile)?  In a turning compost thing?
      thanks.
    2. Scott | Apr 29, 2011 11:11pm | #100
      Cool... Paul's still around (remarkably, considering most of the old guard vacated). I forgot about this thread and I'd like an update too. We've got a newfound interest in composting here.
      Shout out to xxPaulCPxx!!!!!
      Senior Compost?
      1. DanH | Apr 29, 2011 11:34pm | #101
        I think it's time to compost some of these old threads.
      xxPaulCPxx | May 01, 2011 03:47pm | #102
      Well, a leaky roof has taken priority over re-doing the kitchen... so the compost idea is on the back burner at the moment.
      I'm looking at the stuff I'd like to compost... mostly it's fruits &  vegies that have gone bad, stalks, eggshells and coffee grounds.  Of everything, it's the coffee grounds that are the biggest pain as they can stick to just about everything.  I think part of any system has to be within easy reach of the faucet sprayer.
      My basic thought with the ABS pipe would be to create a "torpedo" that fits inside.  This torpedo would have a handle on the end so you could pull it out.  It would also have little ruber disks sanwitched together... these would squeaze tight to the inside walls of the ABS and keep oders out, as well as wiping the sides down as you inserted it into the tube.
      1. DanH | May 02, 2011 07:48am | #103
        Use conduit so you can use "sweeps" for the turns.
          xxPaulCPxx | May 03, 2011 11:23pm | #104
          Interesting idea, but as far as I know we are just going through the wall - no creative plumbing!
  16. recyclingqueen | Jan 27, 2014 10:11am | #105
    Did you build a compost chute?
    Curious - did you ever buld this compost chute?
    I've been thinking of doing something like this and wasn't sure how to go about it.
