Calculating Beam Strength
adastra | Posted in General Discussion on March 31, 2007 05:01am
Thought this might be a good question for Breaktime, I usually am on the Knots side.
I need to build a beam to support up to 700 pounds hung from a chain in the middle of a six foot span.
Anyone know of a good online source for finding the beam strength of common wood construction materials? Thinking of maybe even laminating ply or making a box beam of sorts.
This is basically a wooden gantry crane for pulling an engine if you’re wondering the application.
Thanks,
  1. junkhound | Mar 31, 2007 05:06am | #1
    google "built up beams"
    or look at page 133-140 of "Elements of strength of materials", Timeshenko and Young, Van Nostram, 1964. (my old college text).
    1. mike585 | Mar 31, 2007 05:52am | #3
      junk:
      Thanks to you I dusted off my Timoshenko. Not everyone keeps that edition handy. It was not a best seller.
      Gene_Davis | Mar 31, 2007 06:11am | #4
      Mine, too.  And purchased in the first year of its publication.
  2. mike585 | Mar 31, 2007 05:45am | #2
    From the JLC Structure & Framing Book
    fb=M/S  fb is the max stress tolerable by the material (use 1000 psi for Hem Fir)
    M is the Moment  for your case its 700 lb x span/2
    S is the section modulus 13. 1 for a 2x 8  , 7.6 for  a 2x6
    so for 2 2x6s  it would be M=700 x 72/2= 12600   fb=12600/(15.2)=828 psi
    So you are safe with 2 2x6.  I'd use 3 to be safer (knots or bad lumber) or 2 2x8s
    1. adastra | Mar 31, 2007 06:43am | #5
      Thanks, really appreciate the help.Would have taken me a while to research and apply the equation.
      1. Piffin | Mar 31, 2007 03:23pm | #6
        Wow!
        I would never have thouight of trying to do math on something that small and light weight. I would have just thrown a 6x6 up there, oriented the grain and hung the pulley.
        1. blue_eyed_devil | Apr 01, 2007 07:44am | #7
          Me too. If it bent or bowed or broke, I'd beef it up.
          blue"...
          keep looking for customers who want to hire  YOU.. all the rest are looking for commodities.. are you  a commodity ?... if you get sucked into "free estimates" and  "soliciting bids"... then you are a commodity... if your operation is set up to compete as a commodity, then have at it..... but be prepared to keep your margins low and your overhead  high...."
          From the best of TauntonU.
          1. junkhound | Apr 01, 2007 03:53pm | #8
            dont you guys just all do p l over 4 or w l squared over 8 equals sigma b h squared over 6 in your heads first for rectangualr solids ?
        2. fingersandtoes | Apr 01, 2007 10:37pm | #9
          That's just plain irresponsible. Suppose it came down and you weren't wearing a hard hat? or had tennis shoes on? or shorts? Where would you be then huh? No math indeed!
          1. Piffin | Apr 02, 2007 04:30am | #10
            Head is already damaged as you can plainly see, and I never wear tennies or shorts outside my bedroom
