Doing my first archways. Nothing overwhelming, one is a 30″ opening which will have an eyebrow and the other could be called a barrel-vault archway about 7′ wide. Any suggestions on quick formulas or techniques so it doesn’t take me 3 days to figure out how to make the arcs perfect? Thanks in advance for all responses.
A Modern California Home Wrapped in Rockwool Insulation for Energy Efficiency and Fire ResistanceRelated Stories
Couple of ways. If you are trying to make a smooth curve and need to plot a line to follow I have foudn Coraldraw to be very useful. Get the two year old version for real cheap 'cause elispes and arches are easy to do, you might have to tape a few sheets together but it works.
Free hand drawing, only draw half and then flip over the drawing and copy.
.0175XR(radius of the arch)X Angle.
Example: Arch is 3.5' wide, and it runs from one jamb to the other,
.01745 X 3.5 X 180=11.03' for the "arc."
You probably know this, but it's basic geometry that if you mark the two outside ends of the arc and the high point, the center point of the circle you are wanting to make use of can easily be found.
Simply draw a line from the left point of the arc to the top point. Do the same on the right side.
Go to the center of the left line and draw a line through this center point at a right angle to it. Do the same on the right side.
Where these two lines intersect is the center point of the circle.
Tradesman
Just do it the old boat-builder's way:
Drive a finish nail (or other small nail) half-way in at each end of the arch and at the center / high point. Lay a strip of wood - strapping, ply, whatever - on one side so it touches both the end nail and the center one, do the same on the other side, and tack / nail / screw both together so the angle doesn't change. Then place the point of your pencil in the inside of the "vee" and slide the whole contraption along from nail to nail, keeping the wooden strips in contact with the nails
And there ya go - No triggernometry, streatching string, and no trying to tack up an anchor point for your radius
Doc - The Old Cynic
