There was an article about keeping a house dry. It covered foundations and the author used EPDM roofing put to the foundation with a termination bar. Then he used foamboard under grade to lay the EPDM on and dropped it into gravel drainage bed. I believe he called it a “ground gutter”, but I might be making that up. Can anybody tell me what issue this article is in?
MERC
Not the one you are referring to but Issue #153 has an article about sealing crawl spaces, pp 94-99
OK - The one you want is in Issue #140, pp 64-69
Both written by the same guy, Larry Jenesky
Edited 10/30/2003 12:10:49 AM ET by Ralph Wicklund
