Hi,
I’m planning on building a 2ft high concrete block patio wall and then covering using a stone veneer. Is there an ‘off the shelf’?? cap I can use that will overlap the block and veneer?
Mikey
I can think of dozens of ways to do that ....from regular 1 1/2" thick block to limestone slabs.
Go to a good masonry supply yard and take a look. You will probably see something you never knew existed.
There are cap block with a peak in the center.
