I need help with making connections between pic and cast iron. I have
worked with pic many times but not with cast iron. I can connect the vent pipes with a no-hub gasket to join the pic and cast iron. But I have a “bell” fitting with a rubber sleeve in it to receive a sink drain. Do I just push the pic into it and it seals around it or is there a special pic pipe the connects to it? Also, I have a cast iron waste pipe I need to attach a toilet flange to. Can I use a pic toilet flange? If so how do I attach to it?. Thank in advance for your expert advice.
Learn how to fight wood-boring beetles and prevent home infestations with expert advice from Richard D. Kramer, an authority in pest control.
worked with pic many times but not with cast iron. I can connect the vent pipes with a no-hub gasket to join the pic and cast iron. But I have a "bell" fitting with a rubber sleeve in it to receive a sink drain. Do I just push the pic into it and it seals around it or is there a special pic pipe the connects to it? Also, I have a cast iron waste pipe I need to attach a toilet flange to. Can I use a pic toilet flange? If so how do I attach to it?. Thank in advance for your expert advice.
