walking past this the other day…that’s me…. it and about five more are used to push coal
sorry about the quality.. its my buddys phone so it’s all his fault
Learn about balloon-framing construction techniques, including stud patterns and efficient assembly methods with minimal manpower and scaffolding.
Well, if it's not big enough, there's always it's big brother the D11. If memory serves correctly, it's about 15% larger than the D10.......
Bob
there's an 11?.
.Wer ist jetzt der Idiot
there's an 11?
Yup- check it out on Cat's website. There were a few of them used on huge land development projects when I was in Vegas, but most of them end up in mining operations. I've been across the road from one when it was ripping rock, and I can tell you that the ground literally shakes enough to be scary when that thing sinks it's ripper tooth into the ground and starts to move.
Bob
THAT is BIG........
yup...
there's two up at the Victor mines near here...
they are larger than huge...
did I mention giganic...
man..I find some D10s and think they're huge...only to find out they ain't the biggest....:)and the ..11s are almost commonplace...hahahahand that truck that diamond_dodes posted is TFC...
The Caterpillar D-11 series of tracked-type tractors are among the largest conventional bulldozers in the world, second to Komatsu D575. It comes in two model variations: the standard D11R and the heavier D11R CD.
The D-11 is in the upper end of Caterpillar's track-type tractors, which range in power and size from the D3 with 57 kW (77 hp) of gross power and an operating weight of 8 metric tons, to the D11R CD at 698 kW (935 hp) and 113 metric tons.
D-11s are primarily used for moving large quantities of material (dirt, rock, aggregate, etc.) short distances in relatively confined places. For example, they are often used in quarries. The size, price, power and weight of the larger track-type tractors dictate that they are used primarily for major projects. The D-11 is most commonly found in use in forestry, mining, and quarry operations.
The D-11s are also highly favored for their tremendous power and their ability to rip the earth. They are often used for agricultural and rock ripping. The ripper is the long claw-like device on the back of the tractor. Rippers can come singly (single shank) or in groups or two or more (multi shank rippers). Usually, a single shank is preferred for heavy ripping.
Ripping rock allows the ground surface rock to be broken into small, easy to handle and transport rubble which can then be removed so that grading can take place.
Agricultural ripping allows rocky or very hard earth to be broken up so that otherwise unarable land can be put to use in agricultural applications. For example, much of the very best land in the California wine country consists of old lava flows. Put the D-11 to work and the lava is shattered allowing practical agriculture for the wine industry. In another example, hard earth can be ripped and decompacted to allow the planting of orchards which otherwise could not grow on the land.
The dozer blade on front of the tractor usually comes in 3 varieties:
A Straight Blade ("S-Blade") which is short and has no lateral curve, no side wings, and can be used for fine grading.
A Universal Blade ("U-Blade") which is tall and very curved, and has large side wings to carry more material.
A "S-U" combination blade which is shorter, has less curvature, and smaller side wings.
The nearest direct competitor to the Caterpillar D-11 is the Komatsu D-475. The Cat can be distinguished from the Komatsu by the elevated drive sprocket or "High Drive" system which results in a triangular, rather than oval, shaped caterpillar track.
almost fell ripped off.. huh...
to see a D11 IRL next to a 10 is like a 5 next to a 9....
I have driven some big bad things....
but I had no idea a D10 existed...I had seen the one I stood in front of from a distance but thought they were 9s..there is also some big wheel things on this job....I think maybe 992.
the mines up here have a couple of wheeled front end loaders that are bigger than D11...
they send out this 12 yarder all winter long to dig out the ranches and remote people as good will..
And the rest of the year they level the mt.'s !
that 12 yarder is used for their internal road maint...
you should see the mountain levelers...
that bucket is the one that found that Baja Bronco in the snow drift a few years back....
so 12 yards ain't squat...
View ImageView Image<!--
D11R CD TRACK-TYPE TRACTORSView Image
The D11R Carrydozer is a high production dozing and ripping tool for mining operations.View Image View Image View Image View Image View Image View Image View Image View Image View ImageView Image<!--
797B OFF HIGHWAY TRUCKSView Image
The 797B Mining Truck is engineered for performance, designed for comfort, and built to last. Developed specifically for high production mining and construction applications, the 797B Mining Truck keeps material moving at high volume to lower your cost-per-ton. Rugged construction creates a durable machine. Easy maintenance procedures ensure high reliability and long life with low operating costs.
380 ton pay loadView Image View Image View Image View Image View Image View Image View Image View Image
994F WHEEL LOADERSView Image
Powerful, responsive and rugged, the 994F sets the standard for high productivity and durability.View Image 47 yard bucketView Image View Image View Image View Image View Image
784C OFF HIGHWAY TRACTORSView Image
Cat Off-Highway Tractors have a yoke-type hitch that oscillates four ways to reduce frame stresses. Rugged turn stops prevent excessive wagon rotation in either direction. The rear platform functions as a power train guard and provides a safe, stable work area. Fenders and mud flaps protect from material thrown by tires.View Image View Image View Image View Image View Image View Image View Image View Image View Image
the machines up at Victor mines were featured on one of the big machine shows... discovery - history channel - which ever one had it...
380 ton pay load
Christ man, they could haul a house in that damn thing!
Oh, BTW, that'll teach the guy to park his Bronco where he did! I remember you showing me where that happened, or some place close to it.
the nervey part was he got so upset about it...
HA!
You want BIG ?
Top this!!
http://apollomaniacs.web.infoseek.co.jp/apollo/crawlere.htm
BruceM
but what kind of hole can ya dig with it...
ROAR!!!!
What kind of hole can ya dig with it?
Well, the kind of hole that is made when the space shuttle falls off the platform.
And that monster German trench digger...what in the heck would you use that for? A quick trench in one place. I mean, would it be cost effective to ship it from Hamburg to Salzburg just to dig a deep trench? It would be cheaper to hire 10,000 immigrants from the middle east and give them each a shovel. I mean....look at the pyramids.
BruceM
If you are referring to the pic I posted, when you say "monster german trench digger"...It's not a trench digger. It's used for strip/surface mining.=0)And it makes it's holes deliberatly. Not by accident.;o)
Get over it....... The angry going eat you up. ~Brownbagg '06
That thing just looks like someone is going to lose a limb or two!
No kidding !On the bright side, if the person dies, the body can be buried deep in a nanosecond...;o)
Theere is something similar to that in Sulphur Springs Texas and you can see it from I-30. And yes they mine sulphur in Sulphur Springs.
Luka what is that picture of?!?
It's a bucket wheel excavator.
More here: http://www.answers.com/topic/bucket-wheel-excavator
Top this!!
Well, for dimension, the CTs are impressive. Not much of a ride, though, even empty when they can hit their top speed of around 1.5 mph (yeah, the specs say 2, but the drivers aren't allowed to go that fast, lest it make "ruts" in the roadbed--which is about 6' of different graded gravel surfaces).
An M-9 ACE or CEV seems a bit more exciting to tool about in, really; if much smaller.Occupational hazard of my occupation not being around (sorry Bubba)
Holy crap! I want one.
It is bigI always liked working around big stuff....here are some loco engine blocks, there are 14 in the picture,
the one on the left is an EMD.
Blocks the size of a small car.
Think of how fast you could clear the snow from your driveway with that. And after you did it, you'd have the added benefit of a much wider driveway.
zak
"so it goes"
Well, you could just use a Komatsu 575A2 for that, and remove the neighbor's houses at the same time, so your yard is bigger too. A partial load in a Liebherr T1 and all of the mess is gone. While you're on your way to the dump in the T1, make sure you don't run over any schools or gas stations.
I talked with the oper. said he needs a feather touch with that blade or he starts digging ruts and the engine is just above idle.
Couple more cool pics. These really give you an idea of the size of these monsters.
Edited 12/10/2006 5:09 pm ET by diamond_dodes
yeah....that's the ticket.....size does matter.
I'm waiting till it comes out in a hybrid.
I ran a D9 for a few hours once. I had been running an ancient D7 and got a shot at a brand new D9 That thing was awsome!! Automatic tranny and all hydraulic controls. No strength required - do everything with your fingertips. It felt like you could move the world. - lol
I ran a D9....briefly.... when I was attached to the Engineers in the service, it rocked , literally.
A bulldozer is NEVER too big for the job.
you got that right...
real machines are never too big..
gimme more.
It's no Bulldozer but it's big...
108,920 hp and 5,608,312 lb/ft torque at 102 rpm
1,660 gallons of heavy oil fuel per hr at it's most efficient power setting
think we can get Cat to wrap a tractor around that???
I may be missing something, but I don't see a bearing on that piston.And the rod seems too long.Is the bearing a separate assembly ?Can you tell us how all that works ?=0)
All the info you could want on the largest diesel engine in the world...
http://people.bath.ac.uk/ccsshb/12cyl/
Pretty cool stuff. Should be dial up friendly.
Cool !Thank you.=0)
No problem. It would be interesting to know how long it takes to cast and machine one of those things. Now that would be some interesting stuff :)
holy crap...that's uh really big.
Do you know if they make it in a turbo version?
It is a two stroke turbocharged diesel (first sentence or two of the website). Too bad there isn't a pic of the "right" side. Looking at the cross section drawing, that is where the turbos are.
sorry missed that. long day. thanks.
Cat has got to wrap a tractor around that...
now that'd be something.........
I think that's the one IMERC ended up putting in his Ford PU._______________________________________________________________
What would Scooby do?
I tried...
dog didn't have anyplace to ride...
Plus, hard to go anywhere with rear wheels up in the air._______________________________________________________________
I do all of my own stunts
Marine diesels get to impressive proportions quickly.
Makes the smart-donkey in me want to go down to the parts store and ask'em if they have a set rings for one . . .
....you got it,.
