cedar closet & cedar roof
TimFinn | Posted in Construction Techniques on August 6, 2004 04:22am
customer wants closet built in basement & line it w/ 1/4″ cedar plywood.  Told her probably have to put up drywall 1st since that stuff is so thin.  Got a message – she wants to know if I can just put the studs closer together.  what do you think?  They really won’t be saving much money.  How can I reason w/ them that drywall is an acceptable idea? shouldn’t it be there for a fire barrier?
another question – what is your preference w/ white cedar for roofing – do you treat it or just let it weather naturally?
    Sphere | Aug 06, 2004 04:27am | #1
    just glue and nail it up..it's a closet.
    can't help about white cedar, never used em
    BTW, you mean actual cedar closetliner right? It's chips all pressed and glued..the 5/16 x4 t&g is a lot better.
    RichColumbus | Aug 06, 2004 07:25am | #2
    Just let her know that without drywall... the rest of her basement will stink (or smell nice) like cedar.  It's bad enough with the cedar on drywall... all taped up.
    FWIW, I would also get in writing that it is not warranted that way.  But do it however she wants if she is willing to sign off and it doesn't violate any codes.
  3. andybuildz | Aug 06, 2004 05:00pm | #3
    Put the studs 12 OC. thats all you really need.
    You using the camphor treated cedar?
    I'm using red cedar on my roof ( 60 sq)but used the white cedar on the entire last house I did for the walls.
    Its really a personal preferance.
    All the houses in my historic district have used the red cedar.
    I'd look at the cedar bureau website for more info to help determine the pos and negs for you.
    Be well
    andy
    CapnMac | Aug 06, 2004 11:32pm | #4
    They really won't be saving much money.  How can I reason w/ them that drywall is an acceptable idea?
    What are they afraid of?  Is this a normal closet, or sized more like my first apartment?  You did mention that all the DW would need is simple taping (and not much of that), right?  The point about the fragrance is probably best, the "smell" is what is supposed to keep the bugs away.   With DW up, tell them you do not have to add any material to support the cedar material.
Build a Transom Above a Stock Door
A decorative transom fills in the space between a stock door and the home's 9-ft. ceiling, saving the cost of a custom door.
  • Podcast 569: Bath Fan Installs, Sunroom Trim, and Basement Control Layers
  • Podcast 569: Members-only Aftershow — Rob Yagid’s Addition
  • Fine Homebuilding – July 2023, Issue #316
  • Fine Homebuilding Issue #316 Online Highlights
BOOKS, DVDs, & MERCH
Shop the Store
  • 2023 Tool Guide
    Buy Now
    Buy Now
  • Pretty Good House
    Buy Now
    Buy Now
  • Shop the Store
  • Issue 316 - July
    • Timber-Framed Solar Canopies
    • Build a Transom Above a Stock Door
    • Understanding Toilet Design and Efficiency
  • Issue 315 - June 2023
    • How to Craft a Copper Roof
    • 5 Lessons from Building in a Cold Climate
    • The Advantages of Cellular PVC Siding
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
