Greetings:
I need to have my boiler replaced in my utility room (concrete slab with old 12×12 linoleum tiles). What would be the best way to proceed with this boiler installation with this future tile job in mind? If I try to put some “coasters” under the legs, it may end up too high or too low compared to the height of a tile and they will either have to force the tile underneath or there will be a gap. Should I just proceed with the boiler job and have the tile guy insert the tiles as far as he can under the boiler? The leg height is a full 1 5/8″ so he should be able to at least insert partial tiles underneath if not cover the entire bottom. I know he will have to cut “grooves” or pieces with hemicircles but I imagine it’s been done before.
Any comments on this would be greatly appreciated.
Greetings:
I need to have my boiler replaced in my utility room (concrete slab with old 12x12 linoleum tiles). What would be the best way to proceed with this boiler installation with this future tile job in mind? If I try to put some "coasters" under the legs, it may end up too high or too low compared to the height of a tile and they will either have to force the tile underneath or there will be a gap. Should I just proceed with the boiler job and have the tile guy insert the tiles as far as he can under the boiler? The leg height is a full 1 5/8" so he should be able to at least insert partial tiles underneath if not cover the entire bottom. I know he will have to cut "grooves" or pieces with hemicircles but I imagine it's been done before.
