I have a rental house. 1920’s with old galv supply pipes. There is a clawfoot tub with a faucet that is about 7 years old. Recently the tenants complain that when the taps are turned to a certain point they get a chattering , hammering screeching sound and the water pressure drops. From doing some searching in here it looks like there is something in the valve that is flopping around. So if I go and take the faucet apart will it be obvious what is causing the problem and if not what part should I try to replace to fix it. Do I need to buy a hammer arrester or should I be able to fix the problem with out it. Thanks for any insight. Brian
Michael Hindle explores the efficacy of deep energy retrofits and discusses essential considerations for effective climate mitigation.
Replacing the washers & stem seals in the valves usually fixes this. I have had valves where the stem threads were so worn that it didn't help. In that case, a new valve is in order.
Mike Hennessy
Pittsburgh, PA
