Does anyone one know how to get chewing gum off of concrete? I will be pressure washing and have most tips but have not done gum before. Will the pressure washer remove it or is there a chemical that will do it?
Nobody is as good as they seem, nobody is as bad as they seem either.
dry ice..
WOW!!! What a Ride!
I saw something on TV where they were using steam to take it off sidewalks - NYC I believe.
Dirty Jobs?“The richest genius, like the most fertile soil, when uncultivated, shoots up into the rankest weeds..” – Hume
Didn't seem to be when I watched them do it.
IIRC it just seemed to pop right up.
snork*
an unintentional pun?
brownbagg and MrT, is that you in disguise?...not to want food the next season; secondly, in order not to discourage poor laboring people whom they brought over in numbers from Fatherland. In the course of three or four years, when the country became adapted to agriculture, they built themselves handsome houses, spending on them several thousands."-Thoreau's Walden
Yup, they use a steam gennie in NYC. They go door to door in front of shops, charge by the SQ.FT. IIRC.
Parolee # 40835
Laser
Peanut butter?
For some reason I'm thinking peanut butter loosens up gum...
Must be the peanut oil or else it just attracts the ants to the gum which they devour also.
be devoured...not to want food the next season; secondly, in order not to discourage poor laboring people whom they brought over in numbers from Fatherland. In the course of three or four years, when the country became adapted to agriculture, they built themselves handsome houses, spending on them several thousands."-Thoreau's Walden
Peanut Butter -- That's an old remedy for gum in hair.
As for me, I can't figger out why anybody would be chewing gum off concrete! IMHO, it tastes a lot better right out of the pack.
Mike HennessyPittsburgh, PA
I thought that you where suppose to chew gum off the Bed Post..
Makes it taste better
Fein Multimaster with the scraper blade. Seriously.
Chewing gum off of concrete would be hard on your teeth. I would try to freeze it. We used to spray on freon when there was gum in the carpet. When frozen it is brittle and breaks into little pieces.
