Chimney attachment
Ridgey | Posted in General Discussion on June 14, 2020 07:27pm
Hello all.
 I’ve got a cinderblock fireplace in middle of my pad. I’m building roof over pad with steel trusses and 2×6 purlins. My question is should I attach the purlins to chimney or just frame around it and attach purlins that way? It’s roughly 20’ tall and 32”x24” in size. (Chimney)
Any thoughts would be appreciative.
  1. user-7181011 | Jun 14, 2020 11:10pm | #1
    http://www.rumford.com/training/chimneyclearnaces.html
    I'm not a code expert but the chimneys I've seen were not attached directly to framing. See article.
  2. Frankie | Jun 15, 2020 09:50am | #2
    I was taught that chimneys and framing were separate and distinct components of a house and should never touch.
    Frankie
    1. Ridgey | Jun 15, 2020 11:04am | #3
      Right. My other question would be since I’m using a metal roof would I just bring it tight against chimney and set my flashing over top of it without fastening but fasten to chimney?
      1. Frankie | Jun 15, 2020 01:19pm | #4
        Roof goes close to chimney. Flashing fastened/ tucked to chimney, overlaying roofing.
        F
    LadyContractor | Jun 15, 2020 05:35pm | #5
    Just saw your post. Can’t really tell how the chimney is placed on your roof. If it’s thru the ridge then the following suggestion would not be needed but you would still need to flash and counter flash the chimney. See 903.2.2 regarding the crickets & saddles.
Eichlers Get an Upgrade
Performance improvements for the prized homes of an influential developer who wanted us all to be able to own one.
